6 liter iron block
Old 03-08-2004, 09:10 AM
Spinmonster's Avatar
Default 6 liter iron block
What is the max safe bore size for the iron block for big power. .030? .060?
Old 03-08-2004, 02:19 PM
1999_SS_M6's Avatar
First: quantify "big power." Second: Forced Induction, nitrous, or all motor? If you're thinking upwards of 700hp, I would stick to .030 and under. Also, having the block sonic tested for casting flaws, voids, or weak spots isn't a bad idea either... It could save you a lot of money in the long run.
Old 03-08-2004, 02:54 PM
chino_man279's Avatar
Talk to the guys at AP Engineering------>
They will let you know what is safe for your application. It all depends on what you want to do with the motor as 99SS stated.
Old 03-08-2004, 03:11 PM
BIGBOS's Avatar
.30 to .40
I wouldn't go any more than that............
Old 03-08-2004, 03:18 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
Mine was 4.060 but I was told that most blocks have too much core shift but this one was very good.
Old 03-08-2004, 07:48 PM
Chicago Crew UnderBoss's Avatar
4.030 to 4.040 for big spray usage or other Forced Induction or best reliablity and leaving room for prior rebuilds, etc. 4.060 is the max for N/A and 100 shot to play it safe BUT YOU MUST GET IT SONICE TESTED as many of the new blocks are to thin where it counts for the .060!
Old 03-09-2004, 02:14 AM
4.03 and a 4" crank is a 408ci?....for FI application
Old 03-09-2004, 11:01 AM
ChevyThunder17's Avatar
Yes, a 4.030" bore and 4" stroke equal 408.1 cubic inches.
Old 03-09-2004, 11:30 AM
xp3nd4bl3's Avatar
I'm running .080 over with no problems yet. Big nitrous coming soon.
Old 03-09-2004, 11:49 AM
BIGBOS's Avatar
That should be a pretty interesting setup, did you have the block sonic tested for that big bore?
Old 03-14-2004, 11:13 PM
1999_SS_M6's Avatar
FIRE IN THE HOLE!!!
Old 03-15-2004, 12:03 AM
Mike K.'s Avatar
Originally Posted by 1999_SS_M6
FIRE IN THE HOLE!!!
lol I am interested as well if that blcok was sonic tested that was bored .080
