Sts - Wrapped Exhaust -- Inside!!!!!
Old 07-11-2006, 06:09 AM
smoke20's Avatar
Default Sts - Wrapped Exhaust -- Inside!!!!!
about 2-3 weeks ago there was a thread about wrapping your exhaust on an STS car to get more hot exhaust to the turbo, i was one of the people who did not grasp the concept that hotter exhaust would make a difference. I WAS WRONG!!! i wrapped my exhaust last night and my car is totally different now, it boosts much quicker and pulls harder, i cant wait until i get it to the track to verify what my butt tells me.
Old 07-11-2006, 09:24 AM
Bankz27's Avatar
Where did you get the wrap from and do you have pictures?
Old 07-11-2006, 02:18 PM
smoke20's Avatar
i bought header wrap from advance auto and wrapped my entire exhaust from the header collectors back to the turbo. i didnt take pictures , that will have to be another day. it took 2 50' x 2" rolls.
Old 07-11-2006, 04:06 PM
mattslightning's Avatar
yeah I did the same. What a difference it makes! I actually bought 2 rolls and need to buy another roll to finish just have been to lazy. The reason it helps is because hot air is more dense they say.
Old 07-11-2006, 04:59 PM
Zombie's Avatar
Might wanna just stick to saying it works and not try to explain it
Old 07-11-2006, 05:15 PM
BigPlanTransAm's Avatar
ive been thinking about doing this too, but doesnt header wrap trap moisture and rust out the exhaust?
Old 07-11-2006, 05:49 PM
navymitch12's Avatar
pics!
i want to do this on my car...maybe soon
Old 07-11-2006, 06:05 PM
11 sec. Truck Mod
TIM Z's Avatar
good to know guys, i was keeping my truck running the entire time in the staging lanes for fear of losing heat in the exhaust. I t should help with cold starts also, just seems sometimes after the truck sits it takes a short trip down the road to get full advantage of the turbo.anybody else have this prob?
Old 07-11-2006, 06:07 PM
trtturbo's Avatar
It will help alot Tim. We have done trucks and felt and seen the difference.
Just do it!!!
Old 07-11-2006, 06:08 PM
trtturbo's Avatar
Originally Posted by navymitch12
pics!
Mitch, it will help alot with the 6speed cars. I just did it to a Trans Am a few days ago. The car is still here. When we get it back on the lift, I'll take a few pics.
Old 07-11-2006, 06:13 PM
longrange4u's Avatar
I am with Zombie on that one! LOL
Cold air is dense Matt....
Old 07-11-2006, 06:15 PM
11 sec. Truck Mod
TIM Z's Avatar
Just do it!!!
yeah Billy, i remember your advice on the wrap, i just havent thought about it till i was at the strip last week. better late than never. You the man billy!!
Old 07-11-2006, 07:46 PM
mcx
mcx's Avatar
I heavily wrapped my cat back pipes for starters using the stuff in Jegs..i then used HVAC tape and wrapped the "wrap" to keep more heat retention but also to keep the heat wrap from ever contacting water when driving in the rain...if you have ever used this wrap and get it wet frequently it falls apart fast...you look like you have rags hanging under your car!!i've been using this set up for a couple months and its lasting pretty good...later,mike.
Old 07-12-2006, 11:29 AM
smoke20's Avatar
Just do it!!!
its the best 75.00 ive spent in along time. if it falls apart in one year it would be worth replacing every year. it makes such a difference its hard to explain you just need to get it done. only took about 1 hour to install . ill get some pictures tomorrow.
Old 07-12-2006, 03:50 PM
11 sec. Truck Mod
TIM Z's Avatar
are you talking about the really shiny foil tape that you use to tape duct work insulation together? good idea!
Old 07-12-2006, 04:52 PM
mcx
mcx's Avatar
Thanks Tim,thats the stuff...it's adhesive holds on pretty good but works best if you use hose clamps to reinforce...i spaced the clamps out every foot or so..if you keep the header wrap dry from rain and prevent it from being sand blasted, it should last a long time...aluminum tape is much cheaper to replace than the initial header wrap...give it try and post your results.thx,mike.
Old 07-12-2006, 04:54 PM
LS1Tech Sponsor
hellbents10's Avatar
Yes Tim I would definatly give it a try.
Old 07-12-2006, 05:01 PM
WestSide's Avatar
THink I could get the wrap on the kit while it's on the car???
Old 07-12-2006, 05:36 PM
Nickn20's Avatar
actually cooler air is more dense, hot air takes up more volume, so keeping the heat in the exhaust pipe will effectively take less effort from the motor to fill that pipe and it spools the turbo, you guys would be suprised to feel a front mounted turbo with wrapped headers I have a 67mm hitting full boost by 2800 and it starts to spool at 2k.
Old 07-12-2006, 07:40 PM
11 sec. Truck Mod
TIM Z's Avatar
Ill wrap it so its ready for your dyno. I need to see the doctor .LOL
Quick Reply: Sts - Wrapped Exhaust -- Inside!!!!!
