LSA won't make more boost
Old 06-22-2024, 02:58 PM
rpturbo's Avatar
Default LSA won't make more boost
Has anyone ran into a issue where a LSA won't make more boost?
Car has made 11.7# with a 2.55 on it. Swapped to a 2.38 car makes 12.1#. it should be making more according to the pulley maps. The belt is a green belt, with a high end tensioner on it. Does not show belt slip in data.
It has a 3.5" inlet tube and a 92mm T.B on it. I'm wondering if maybe that is the restriction? Going to try pulling it off next time I'm around the car, but it seems like that should be enough.
Old 06-22-2024, 09:15 PM
jayyyw's Avatar
Those types of blowers really need to breath. The air intake and TB are the restrictions. I don't know what pulley combinations are supposed to make in terms of boost, but that pulley change should have made more than .5 a pound. Is your wastegate working correctly? Could be venting boost and you not know it.
Old 06-23-2024, 07:17 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,143 Likes on 743 Posts
Hit up Rick Crawford on FB, maybe he could help.
Old 06-23-2024, 07:39 PM
rpturbo's Avatar
Thanks guys. Yeah I know normally one of the first upgrades guys do, is a 5" inlet.
This has a 92mm TB on it, and I verified today, that the TB matches the snout inlet so I guess that part should be fine.
I'll pull off the inlet next time the car is out. We were expecting somewhere in the 14-15# range.
Also verified the little valve is sealed up good today.
Old 06-23-2024, 09:16 PM
LS1Tech Co-Founder
I think lexi went 9.7s with an LSA in her G8 back in the day, if you are friends with her maybe ask her pulley combo.
Old 06-30-2024, 02:11 PM
rpturbo's Avatar
So it turns out, a 3.5" inlet tube won't flow enough air to go over 12#ish. Took off the tube, it's making 17# now. Now we are getting somewhere.
I guess this is why they run 5" inlet tubes.
The following 4 users liked this post by rpturbo:
jayyyw (07-03-2024), Keith (06-30-2024), LilJayV10 (07-09-2024), ryeguy2006a (07-10-2024)
Old 06-30-2024, 09:54 PM
gnx7's Avatar
Sent out the snout to get ported and run a BIG throttlebody. Really wakes those blowers up. Also your reservoir should be as large as possible as these blowers are super prone to heat soak.
I have the green belt and orange square brick seal both new for $40 shipped if you want them. DM me.
Jimbo1367 (07-08-2024)
Old 07-08-2024, 02:55 PM
rpturbo's Avatar
It's a buddy's car. It has a reinforced brick in it and new seals. He is talking about having it ported this winter. It's starting to get with the program now.
Old 07-08-2024, 05:20 PM
Full Power's Avatar
You could FEED it Pre-Boost with a big, Lazy Turbocharger...
Wouldn't take much to make a YUGE difference.
Even 5 or 6 PSI at Throttle Body Inlet would make a screaming world of difference.
You would need a pretty big INTERCOOler for such a compound.
Quick Reply: LSA won't make more boost
