383 Build Advice..
I have an '88 s10 blazer that I'm intending to build a 383 for...
It is a tbi one-piece rear main seal, block needs to be bored at least .030.
Also, being a two bolt main block, I intend to use Eagle Products Splayed 4-bolt main caps..
Plans include an Eagle 3.750" stroke crank, 6" Scat rods, and Speed Pro forged pistons. I've been gathering info on Brodix's Track 1 heads with a 221cc intake part, 3/4" thick deck, 67cc chambers.
I'm currently undecided on cam and remaining valve train, as well as induction, although I've had my eye on the Edelbrock Victor Jr, as I understand the manifold works well with my head choice and to my surprise have read alot about the manifold being rather street-friendly.
I also plan on up to a 200 shot plate kit.
Goals are to run at least 7's in the eighth mile, on motor. 6's on spray.
Truck will also be four-linked and am still undecided on rear end selection, as well as tire size and gear ratios. Also, will be using a th-350 transmission, thats getting built after the motor is complete.
Will see probably 60% of it's time on the street and 40% track...
Thanks for looking, and any advice is greatly appreciated, thanks guys!!
I do believe 7's are a believable goal, as it weighs just a tad over 3000 pounds.
Thanks for your advice...
Looking in the Jeg's catalog the Comp Cams hydraulic roller lifters (part # 249-818-16) states that 87- up block requires modification, anyone know what may need to be done?? Lunati's lifters for the same engine has no denotation that it'd require any thing.
The cam I'm looking at is a Comp retro-fit roller, advertised duration is 299/319, rpm range is 2500-6200, and lift is .531/ .517... I'm thinking this would be a good nitrous cam with the longer exhaust duration.
If anyone else has a cam that they think would better suited to what I intend to do I'm all ears.
Thanks for your help guys!
l
Goodluck!
edit.. I have eagle 4340 crank and rods.. Also shifted the XR292 at 7000 rpm.,. Did it need 7000? Maybe, maybe not.. it felt right to me, never dyno'd it..
I'm starting on my bottom end here in a couple of weeks, ordering parts and getting machine work done...
Guys, I really appreciate your help.
Thanks y'all!!
I'm still leaning towards the 215cc Track 1 heads, I've read absolutely nothing but good things about them, even with hydraulic flat-tappet 355's!!
Corey, I'll be looking to give you a call here when I get some free time..
Thanks again fellas!
Track 1's are comparable to the Darts. Both can be ported to make well over 700hp if you ever wanted to make big power and work well out of the box. No reason why they can't make 600+ hp right out of the box.
AFR Eliminators don't dissapoint either, similar price range.
I don't think 220-230cc heads are too big for a 383. Different engine but look at the LS engines. NOBODY stays with a head under 225cc these days.
Don't be afraid of a solid roller on the street. Other than checking lash to be safe, I never had rockers actually NEED to be re-adjusted.
http://www.pacificp.com/forum/viewtopic.php?t=7903
Not only did the cast Eagle crank break on this guy (and others have had the same problem), Eagle didn't do a very good job of trying to make it right either. Just something to consider.
