fuelie head questions
i have some questions that i hope you guys can answer
i wasnt really sure where to put this question, but i think this is the best place
i have a 327 out of a 67' impala ss
can anyone tell me the valve sizes they put on the 462 heads on this year?
im assuming since it was the ss, they used the 202 and 160 valves, but im not gonna say anything until i know for sure
also, can anyone give me ANY info you have about the 462 heads?
i am doing google searches and everything, but all the info i can get would be great
thanks!
thanks!
A 462 casting from a '67 Impala came stock with 1.940 intake valves and 1.50 exhaust valves. The valve sizes can be enlarged but they would have come stock with those sizes.
im actually just trying to find out more about the engine i have
how do the 462's flow compared to all of the different fuelie heads?
i have seen people say they are the worst flowing, and i have seen people rate them as the best flowing out of all of them
lets say these are the stock heads/valve size (even though i would not be surprised if they have the bigger heads) but how much hp do you guys think this engine is getting:
its a 327 out of a impala ss 67' bore/stroked to a 355:
weiand xcellerator intake (high rise)
long tube headers
comp cam 280h cam (.480 lift, 280 duration)
block milled down, 12.5:1 comp
holley 600cfm carb (once i get the money a 750 is going on there)
crappy accel HEI (once again, when i get some money a msd pro billet and 6al box is goin in there)
i understand im not gonna get an exact estimate, but just a rough one would be great
sorry if i left anything out.. i just woke up not too long ago
They were good for the day, but almost everything these days outflow them by far! I used to run the fuelies before the after market supplied good inexpensive heads, early 80's in my case. I ran the bottle back then and would crack fuelie heads left and right.
Unless you are using them as is, they will just cost you more money in the long run.
once i fix the body and get it driveable is when i will start to do engine work
but for now they will do
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
