Street Racing & Kill Stories Basic Technical Questions & Advice
Odarabla's infinite BS thread for the foreskinned (AKA Smack Down)
Old 10-22-2013, 12:54 PM
  #20881
Camper's Avatar
Originally Posted by AnnivSS
A 2.0L 4 cylinder wont gain 15-20 whp per psi. Stock evos are 260 crank hp at 18 psi from the factory, if it gained even the low end of 15whp per psi youd be looking at over 400whp just from the boost gain.
yea I wasnt paying attention to this being an evo convo. Thats out of my knowledged area
Camper is offline
Old 10-22-2013, 12:56 PM
  #20882
Blown383LS1's Avatar
LS1Tech 10 Year
Originally Posted by Heater
Some TEA's
You going to try a set of the new 11r's?
Blown383LS1 is offline
Old 10-22-2013, 01:04 PM
  #20883
Heater's Avatar
I've went round and round about swapping to E85. We don't have it locally, except in pails at the local speed shop ($7 a gallon). The closest station with it is over a hour away from me in a remote rural area that I wouldn't bank on them carrying long.
If/when we get it more closer, more accessible I will make the switch.
Heater is offline
Old 10-22-2013, 01:08 PM
  #20884
Heater's Avatar
No, I'm looking at stepping up to a set of 240 Street Heats. I currently have a OLD set of 225 KPI/Street Heats.
Heater is offline
  #20885
ZFreie's Avatar
Buy a drum at a time? I dunno if you would use it fast enough tho.
ZFreie is offline
Old 10-22-2013, 01:10 PM
  #20886
ohioborn80's Avatar
E85 stays good for a year long as sealed right. And screw paying 7 a gallon for it. Buy a drum and save money.
ohioborn80 is offline
Old 10-22-2013, 01:16 PM
  #20887
sw07gt's Avatar
E85 was $2.77 at the pump today.
sw07gt is offline
Old 10-22-2013, 01:24 PM
  #20888
willizm's Avatar
Originally Posted by Cwarta
I agree, it's going to be tough and will require some expensive heads . However I know it's achievable and plan to try .
As far as e85, a local tuner said just the switch is worth 3 ish %, plus I'm pretty aggressive on compression. Also, I've seen a few dynod were n/a have picked up 25rwhp a gross the board just from more aggressive timing.
I dunno about your particular setup but for turbo cars e85 is great stuff as we can run alot more timing and boost than we could safely on 93octane. With your setup running e85 with high compression would just give you a higher ceiling for safety and if you can run a fair amount of more timing then you would probably reap a bit more than just that small 3% gain. Guys on stock motors with normal compression would see that small amount of change and there isn't as much of an issue with normal compression ratios on pump gas as you would encounter with high compression on pump gas. Just a thought. Look into high compression motors like yours to see what others have gained with e85. Turbo guys it's a no brainer.
willizm is offline
  #20889
LS1Tech 10 Year
TEA does great work. I have a set of their TW 205's on my car now.
Old 10-22-2013, 01:59 PM
  #20890
Cwarta's Avatar
Will do, I need to do more research on the gains. Obviously yes it's a no brainier for boosted .
As far as $7 a gallon wtf! The ONLY pump here in town is $2.25 lol
Cwarta is offline
Old 10-22-2013, 02:06 PM
  #20891
flattusmaximus78's Avatar
Whats needed to change over to e85 on an ls like mine? 02 z28, stock fuel system save for an aeromotive 340lph and fast 36lb injectors?
Curious...
flattusmaximus78 is offline
Old 10-22-2013, 03:21 PM
  #20892
ohioborn80's Avatar
TF 255 heads ordered.
Old 10-22-2013, 03:22 PM
  #20893
ASSuming On The Tree
audacious nick's Avatar
Depending on your ECM, you can always turn your car into flex fuel compatible.
audacious nick is offline
Old 10-22-2013, 03:24 PM
  #20894
ohioborn80's Avatar
Curious...
Why would you waste money doing it on a stock car? Do bolt ons, cam etc then do e85. The gains will not be worth for stock. You need the injectors, boost a pump atleast on stock car.
Old 10-22-2013, 03:30 PM
  #20895
Poppacapp's Avatar
Originally Posted by Lawhead
So you picked up 60rwhp from 8 pounds of boost and more timing ?
Average hp gain are about 10rwhp per extra pound of boost.
Poppacapp is offline
Old 10-22-2013, 03:34 PM
  #20896
Lawhead's Avatar
But e85 alone didn't net his gains. That's how bad information is spread ....
Lawhead is offline
Old 10-22-2013, 03:36 PM
  #20897
evangto87's Avatar
Originally Posted by Mike Morris
Correct. Cecil is second to last exit on 95. Atco second exit on nj turn pike. You can do it in about an hour with no traffic. Done it many times
Interested in meeting up some time at Atco? Likely in the spring time that is. I have to dial this car in a lot more at my local track before i travel
evangto87 is offline
Old 10-22-2013, 03:56 PM
  #20898
Mike Morris's Avatar
LS1Tech 10 Year
Sure. I spend most of my time at my Fl home but I return back to Md every few months to check on house etc. Should be easy.
Mike Morris is offline
  #20899
sw07gt's Avatar
I've always thought that it was implied the car was retuned anytime someone says they gained xxx hp from switching to e85/110/116 etc.
sw07gt is offline
  #20900
Lawhead's Avatar
You got a date with a Silver cobra first ....
Lawhead is offline
Quick Reply: Odarabla's infinite BS thread for the foreskinned (AKA Smack Down)
