1999 trans am vs 98 gst
My car: details in sig
vs
1998 gst eclipse
The eclipse owner is a friend of mine and he just got his car done a few days ago. The specifics of the eclipse I am not sure, but I know it is a T3/T4 turbo with built motor running on 12 pounds boost. He is still breaking it in before he sets boost to around 25 pounds is what he told me.
The race is about 35 to about 90-95ish.
http://www.youtube.com/watch?v=zSQly23nkdM
vs
1998 gst eclipse
nice vid (camera man knew what he was doing) but not a race at all. Considering how bad he lost, I don't think adding those 13 more pounds of boost are gonna be enough!
I'm sure he gets this **** all the time, but why didn't he go with a GSX? Just couldn't find one/didn't want to pay extra for the AWD compared to how common the GS-T eclipses are?
What is he "breaking in"??? I've never understood why people baby a motor for 1000 miles yet they will give it hell at a lesser power level. ![Suspicious](https://ls1tech.com/forums/images/smilies2/suspicious.gif)
Put the motor together, set the timing ASAP, make sure there are no leaks, go put some loads on the motor to help with the rings, then give it hell. Now I do believe in breaking in clutches.
Yes I was on motor.
Thanks!
Bored .20, eagle rods, weisco pistons, 650cc injectors, bigger turbo, and supporting mods.
From what he was telling me yesterday he is still running stock injectors and boost because he is waiting for ecm/dsm link so it can be tuned and ready to go. So basically he CAN'T run it to full potential until he is tuned.
Lol, I know nothing about turbos and don't pretend to, I was just going on the info he gave me. I will try to get more specifics on it.
If his "T3/T4" turbo is a common Garrett .50-Trim, as I would guess it is, he should be able to make 450hp at the crank on pump gas, maybe a bit more. However, I don't think his 650cc injectors will be able to support that...maybe 400hp. He should get 850cc or bigger if he has ECMLink.
The stock 450cc injectors on a DSM aren't good for much more than 250whp, if that, so I'm happy to see that he is keeping boost low. He seems to know what he is doing, waiting for ECMLink before putting larger injectors in. ECMLink is what I use, and it's a great tuning device.
With that engine setup (as long as it was built properly), his bottom end will be good for 700hp (although that would be useless with FWD).
