Mach at the track
#1502
#1503
god what a bunch of morons. i nor hiho ever said the motor wasnt stock. he used the kb or whipple as an example that heaters car isnt stock. at the same time heater never said it WAS stock. he just named alot that is still stock. then morons get ahold of it that cant read and twist it into a mess
#1506
List of tires I've run and my thoughts on the street
BFG DRs I: Were too soft and never hooked. Just made pretty black marks
MT DRs:
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
BFG DRs II: Meh, not too bad
Nitto DRs: Got a love/hate with them. When they are new they are great. But after a year or so of being out in the weather they start to suck.
I had a pair of Hoosier DRs for about 4 days but never tried them.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#1508
My blower has been upgraded to a Ford Racing supercharger, and it has full exhaust with a boost-a-pump...unless you want to get real sticky tacky and start counting lowering springs and a MGW shifter..oh and a BillitFlow rear end brace.
You see it at the track like you see it on the street, with the exception of the rear tires and the spare tire and jack removed. My car has less mods and more street driven than any of these hacks in here trying to put down other peoples cars.
#1509
#1510
#1512
So if I had a garage, and I buy a brand new Vette, Camaro, Mustang, etc. Always keep it garaged because it is my toy and I only take it out on nice days or days when I have a friendly meet or something when the weather is nice. Don't take it to the track because I just like cruising and doing the occasional race on the street. When I play around, it doesn't hook on the street - so I decide to ditch the tires on it for drag radials, on the stock wheels. The car is completely stock, btw.
Now I have a racecar?
![](http://cdn.memegenerator.net/instances/400x/35284777.jpg)
#1514
#1515
H/C/I on pump gas can make 385rwhp with little torque. thats an all out effort, and hardly worth it.
i will never dyno the turbo without boost, but it is likely in the 280-290rwhp range. not much to brag about.
#1516
#1517
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
car runs good Heater.....just givin you ****.
I probably have the most mods to my car and near the least on my engine.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#1518
Can you imagine either if our cars running with just the added boost?? Heat is probably running 16-18lbs. That would put us @ 8-10lbs...damn, even if it's only 6-8lbs it's still damn.
#1519
I don't know about the mileage man....I have 115k on mine. 80k on the ls6. I don't consider any engine running at more atmosphere's stock. So now you needed to upgrade your fuel system to handle the extra boost......and after all the making fun of the 10bolt the ford guys do you braced yours up to live........oooohhhh the irony.
So you run it like you do on the street....except w/o slicks![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Mine weighs 17#![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Mine weighs 17#
The car had the brace on it when I bought it, so it is what it is.
LoL, my car goes against about all you believe in I think.
#1520
Better yet, imagine what my car would run at your weight and all your low rotational mass tricks?
