06 GTO, 01 Camaro, 10 GT and 04 MACH 1
#125
#129
Yea right. My vert is down to 3450 with a 150 lbs removed. My T-top A4 SS was about 3350 with weight (about 100lbs) removed. Both full interior.
No Camaro is lighter than 3450 lbs stock. Verts are 3600 lbs. GTOs are all over 3800..so if you have weight reduction, let it be known that you are comparing YOUR camaro to stock GTOs, not all Camaros vs GTOs like you have been.
Unless you're trolling, in which case you just suckered me into responding. Congrats.
#133
IRS simply does not compare with SRA, either. Let's see a stock suspension and rear end gto that runs 10s(this is an example, an EXAMPLE
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#134
If there were to be a poll on ls1tech as to which is faster stock for stock and mod for mod, it would unanimously be the f body in one (if not both) categories.
#135
Stock for stock? Like LS2 GTO vs LS1 F-body? I doubt you'd see the results you're predicting, also...unanimously? You know what that word means, right? It means every single voter would vote for the f-body without a single vote for the GTO.
#136
It was a figure of speech, a hyperbole.
#138
Mod for mod and stock for stock, f body > gto. Once you start modding both it becomes clear which is the better platform, I used the tubular k member as one of the many advantages of the f body once you start modding both. Thought the context and meaning of the example was clear, guess not.
