Street Racing & Kill Stories Basic Technical Questions & Advice
Epic SRK B/S thread of 2019
Old 09-21-2021, 05:10 PM
  #8281
HioSSilver's Avatar
Well the carrier is typically considered to also be the posi /locking unit only. Sounds like the set up on the gears were off.....possibly other **** going on like in cman's rear. That thing was all kinda fucked up. Took me a bit to figure out that amount of fuckery.
I wish i woulda figured it out for myself on my 9". I sent it out due to not having the time to do it and there was a bearing that was crossed wrong. But it's noisy, not terrible but bad enough i don't like it. That's what i get for not doing it myself.
My center is aluminum too. All for 2500😁. It came with a cm driveshaft and lca's. Was a good deal and even had the right gear for the bolt on ls6. The new engine will probably want nearly 1k more rpm so it might need a gear change. I was thinking 4.22s. Might just do 4.00 since i have a set of those.
Old 09-21-2021, 09:54 PM
  #8282
CamOnlyJabroni's Avatar
My cam with 28” tall tires definitely wanted more than 4.30’s. It drives really nice now. Just waiting to get it back on the road after my throw out bearing failed and found out I was only using half of my clutch while disassembling everything. Nice twin disc McLeod. Over .0030 of runout from one side of the flywheel to the other. Picked up an adjustable slave cylinder while everything was apart.
Old 09-22-2021, 12:33 PM
  #8283
FinalCam's Avatar
My car loves the 4.56s. I have a buddy with a cam only ls1, 28" tires and 4.30 gear and the car is begging for more gear. Makes peak power close to 7000
Old 09-22-2021, 03:58 PM
  #8284
that’s right where mine is peaking. 6,800 but carries to 7,3-7,400. Exact same boat as him. 4.30’s to 4.57’s changed its life.
Old 09-23-2021, 03:15 PM
  #8285
spikestang's Avatar
here is a extremely gutted out 2000 2v gt vs my camaro ss
The following 2 users liked this post by spikestang:
NW-99SS (09-27-2021), S8ER95Z (10-12-2021)
Old 09-23-2021, 04:39 PM
  #8286
HioSSilver's Avatar
2v are lol
Old 09-23-2021, 04:40 PM
  #8287
HioSSilver's Avatar
I need to dyno before i decide on gear.....see what dat tq curve is like.
Old 09-23-2021, 05:26 PM
  #8288
spikestang's Avatar
2v are lol
it was fbo, and 2500 pounds lol. I would keep those 3.90 gears you have, these cars spin kinda bad on the street with a bunch of gear.
Old 09-23-2021, 06:35 PM
  #8289
HioSSilver's Avatar
It runs almost 60mph by the end of 1st gear. It should turn somewhere in the 7400-7800 rpm area.
What these cars really need is the 2.9x gearset for first gear.......then make it have traction.
Ima move the battery to the back at some point. I did that to the mustang and it was a noticeable difference. Never ran it at the track like that for good data tho. But really helped on the street.
Old 09-25-2021, 09:22 PM
  #8290
I run a 18x11 out back with a 315/40 NT05R. With my QA1’s dialed in it hooks pretty hard with 4.57’s. My car doesn’t come off the cam till 2500rpm so it needed 4.57’s for better drivability alone. Added performance is just a bonus at this point.
Old 09-25-2021, 11:23 PM
  #8291
snake95's Avatar
Relocating that jet ski battery should definitely help things in your max effort race car.
The following users liked this post:
islander033 (10-04-2021)
Old 09-26-2021, 12:00 PM
  #8292
HioSSilver's Avatar
It has a full size battery in it. It's also gonna take me to work over a hr tomorrow.
What were you saying? I kinda forgot
Old 09-27-2021, 09:33 AM
  #8293
NW-99SS's Avatar
2V was exterior gutted too - new SRK mods!
spikestang (10-01-2021)
Old 09-28-2021, 09:24 AM
  #8294
S8ER95Z's Avatar
I still have the 10 bolt in mine… been lucky I guess. Original one lasted to nearly 200k, I’m not sure I love the 3.90s though… kind of miss the stupid long gearing and gas mileage from the 3.42s.
Old 09-29-2021, 08:16 PM
  #8295
HioSSilver's Avatar
I never seen much difference in mpg. The car got it's best highway mpg with the 4.10s in it actually.....29.1
S8ER95Z (10-01-2021)
Old 09-30-2021, 06:44 PM
  #8296
Cole Curtis's Avatar
This guy got 40mpg in a c5 if your worried about gas mileage. Lean that **** out
Old 10-01-2021, 02:47 PM
  #8297
zz4camaro1980's Avatar
I know there's a lot of Florida peeps in here, who's in for a Drag Week style event in FL?!
I hope this happens, I ran Drag Week 2019 with Tom Bailey and he is the man!
AnnivSS (10-23-2021)
Old 10-01-2021, 08:18 PM
  #8298
spikestang's Avatar
My oil pump broke in a few pieces, when I was at 6000 rpm, I went from 80+ psi, down to 0, I hope I caught it in time.
Old 10-01-2021, 11:38 PM
  #8299
S8ER95Z's Avatar
Whoa that’s a mess… hopefully no other damage?
Old 10-02-2021, 07:19 PM
  #8300
spikestang's Avatar
so far so good, I just put 20 miles on it, with no issues, knock on wood. If it makes it 100 miles I will be less nervous.
S8ER95Z (10-03-2021)
Quick Reply: Epic SRK B/S thread of 2019
