Raped a 5.0
Caught up to him and ran him again from 70 while I was in 4th. I think I ran him, seemed like he KINDA hung, a little. I couldnt really tell.
We pulled over, chatted. He said "hi(him)" "hi, im Jon, nice runs!(me)" "Those things are bad *insert story of 10-second TA owned by friend* (him)" "I am still stock (both of us)" *compliments all around*
Judging by the rims it was a 89-93. It had a 5-speed.
Want to take your chances against my 5.0?
Even if he was a cool guy, now he will go around talking about how he hung with an LS1 car, etc, etc. That race shoulda ended with you bus lengths ahead. In my experience either go all out or just dont do it at all. My .02
I dont like going much over 70 crossing a bridge that has an on-ramp and an off-ramp and a truck stop at the end of it. (Bridge crossing I20, about 200m long) I ran it out to the top of second and then when I saw him still there on the gas trying to catch up, a TINY BIT into 3rd. I was hoping it would end after 2nd.
I did not turn off TCS because I saw no need to.
Meltdown...shreveport, LA. I bought the WS6 just to play with and not really to run it. I only run stuff that I just happen along side. That being said I did totally rape my 5.0 which has every mod known to man
, I just went cheap on the heads and kinda payed the price in performance. Still. What is your 5.0 packing? I did not turn off TCS because I saw no need to.
What do you have?
PS. You claimed to have a "5.0" to me that means a car with a 302ci motor (although 305 is 5.0...anyways.). The reason people called the fox-body mustang a 5.0 was in reference to the only thing in the car worth a damn in my opinion (having owned one). So if you do not have a mustang with a 302 or 306. It is NOT! a 5.0 and thus I would have been mislead if I had challenged your claimed 5.0 if I am to belive the insinuation that you made about having more cubes.
PSS> it is late and I have a test tomorrow. Thinking analytically.
BTW It's ok to be a student in college. To answer your previous question; I have a Mustang with an Edelbrock Performer RPM intake, throttle body, 4:10 gears, and a 5-speed. Nothing to be scared of I just want to try it out with someone. FWIW I haven't raced a 5-speed car in 3 years
BTW It's ok to be a student in college. To answer your previous question; I have a Mustang with an Edelbrock Performer RPM intake, throttle body, 4:10 gears, and a 5-speed. Nothing to be scared of I just want to try it out with someone. FWIW I haven't raced a 5-speed car in 3 yearsGT40P heads
X303 cam
575 speed demon carb
MSD 6AL
MSD Pro-Billet dizzy
RPM Performer manifold
1.6 aluminum RR's
MAC shorties
O/R X-pipe
Force II Flowmaster dumped pre-axle
4.10's
Billet flywheel/king cobra clutch
Underdriven crank pully
17" Flex-fan (stainless steel, thing was intimidating and damn sharp!)
FMS aluminum DS
Full-length subframes
tq-box kit
welded axle tubes
140mph dash cluster from an 89'
Probe Forged pistons
That is what I can remember from my 5.0 mod list. Everyone on this forum remembers when I joined. My goal was to use a stock displacement 302ci motor to take down an LS1 car. I did it. Just once. It was an auto Z28 from a 75mph punch and it was a SLOW! crawl. I think his car was out of tune or had a plug wire missing. My setup dynoed 244/262 with 13.0:1 A/F with the air-filter removed. The car trapped a best of 98.54mph. At first I thought WTF?! something is wrong!!! But I looked at A LOT! of other 5.0 combos and saw that with all my mods and crappy tires, thats about all I could expect. Low 14's/high 13's @ 99 mph or so, give or take.
To make REAL! power from a 302 takes Trickflow/Brodix/AFR heads and LT's and a .530-.560 lift custom ground cam to match the combo.
https://ls1tech.com/forums/showthrea...6&page=1&pp=20
This ^ race was the result of my BONE STOCK! 01 M6 WS6 running the above described modded car.
https://ls1tech.com/forums/introductions-greetings/378392-new-ls1tech.html
^Me being ignorant a couple of years ago
https://ls1tech.com/forums/street-racing-kill-stories/378269-killed-ls1.html
^Looking back on it...this guy RAPED me, although it WAS unfair. (I was still EFI)
https://ls1tech.com/forums/street-racing-kill-stories/373739-s2000-vs-5-0-a.html
^Me vs. Stock S2000 (I was still EFI)
I ran several 350Z's and the outcome was pretty close each time.
My point is, you sound a lot like me when I joined. This will save you a LOT OF MONEY AND TIME: Buy an LS1 F or Y body. Period. "Oh I can beat them with good heads or a power adder!" When they spend $2000 and get a cam/LT's/a tune/worked LS6 heads and lay down 425whp and come looking for you it will be sad.
My 95 dynoed 246/290 with stock heads e cam and boltons, I ran 12.8 at 106
I currently have a well matched P setup and dyno 295/321. I have a mild 218/224 cam. and my current setup is a few hundred pounds heavier with the Handling-minded suspension I have now. Dont worry I dont have a chip on my shoulders about beating any ls1. Your information is whack. Your combination on your mustang was absolutely retarded.
The only thing you are somewhat right about is afr/trick flow heads with a holley intake or RPMII. You can have a descently running HC setup that you can get 112-115 mph. Then you bottle it or Blower it. Thats just what you do next, nothing wrong with it. Especially when you can pick up a vortech setup for a fox for between 1-2k.
GT40P heads
X303 cam
MSD 6AL
1.6 aluminum RR's
MAC shorties
O/R X-pipe
4.10's
FMS aluminum DS
tq-box kit
welded axle tubes
