Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- Camaro and Firebird Brake Modifications<br>Overview of popular modifications to customize your Camaro or Firebird.
- Chevrolet Camaro 2010-2015: Brake Modifications
CTS-V Brake Install w/ Pics
#325
The easiest way to see if you will need a spacer or adapter is to measure your stock brake setup (12" LS1 rotor and caliper) and see if you have at least 1 1/4" of spoke clearance. Once you take into consideration the new rotor offset and the new caliper thickness, the conversion will stick out 1" more than stock.
#328
Only reason I think I have such a small initial spoke to caliper gap is because my pads are almost 100% still so the caliper is pushed out as far as it ever will be. This is the only think I have not seen anyone consider when initially measuring the spoke to caliper gap. Am I wrong for taking this into consideration? or have we all overlooked this observation? Can someone please shed some light on my predicament?
#329
I had ~1 3/8" clearance with my stock caliper and was just barely rubbing when I test fitted my cts-v calipers, ended up just getting the 15mm spacers listed by others. My wheel did NOT stick out an 1" more than stock, and that's why the spacer...
Like Jason mentioned, best thing to do is to test fit with your wheel and see what you need.
#335
#339
well heres my brakes. well painted n e way. cant wait to get em on. need to detail my car. goin to the sticker shop to get some brembo stickers for them. debating on white, silver, or black. leaning towards black.
#340
those look great! paint or powdercoat? as for the skinnies i found out that ccw makes a custom 17 that fits over them! i thought it had to be an 18+ but he said its the same wheels they sell to the c6z06 guys...
