Old 05-13-2016, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Browse all: Brake Guides
Print Wikipost
CTS-V Brake Install w/ Pics
Old 08-05-2012, 02:06 PM
  #381
UNDER PRESSURE MOD
The Alchemist's Avatar
[quote=trans_am7935;16592172]those are for the rear, you can tell my the strait crossover line. here is the front one.
Amazon Amazon
Cool. Thanks for the link. I'm going to pick up a pair just to test fit to see if my CCW's will clear it. Supposedly they will as they are for a G8 which came with the Brembo's from the factory, so we'll see.
Old 08-08-2012, 02:24 AM
  #382
twarner22's Avatar
This is an awesome write up!
Do you know if i will run into any problems doing this for my 94 z28?
Old 08-08-2012, 01:53 PM
  #383
Killer_Z's Avatar
amazon has nice yellow 6 piston cts-v calipers. very nice. not seeing matching set. left right.
Old 08-08-2012, 02:20 PM
  #384
bluestreak98's Avatar
http://www.amazon.com/ACDelco-172-22...xgy_auto_img_c
That is a good price compared to partstaxi...
Is that the left or right side? It doesn't say?
Old 08-08-2012, 03:16 PM
  #385
UNDER PRESSURE MOD
****! I didn't even think about needing a different one for left and right. ****.
Old 08-08-2012, 03:27 PM
  #386
UNDER PRESSURE MOD
Looking at that, I'm guessing you swap the bleeder screws for the cross-over and that converts it left to right.
Old 08-08-2012, 03:58 PM
  #387
Killer_Z's Avatar
ahh. ur good.
Old 08-08-2012, 04:45 PM
  #388
twarner22's Avatar
Are these 04-07?
Old 08-08-2012, 05:41 PM
  #389
UNDER PRESSURE MOD
Originally Posted by twarner22
Are these 04-07?
04-07 had 4 piston brembo's, and the 2nd gen cts-v's were the ones with the 6 piston ones.
Old 08-08-2012, 09:43 PM
  #390
Wesmanw02's Avatar
Tha would allow you to bleed it properly, but your brake hose fitting would still be facing the wrong direction. I suppose it would still work just fine though.
Old 08-09-2012, 04:54 AM
  #391
Pony Exp.305's Avatar
good write up..
I ll look at amazon and taxiparts....
Old 08-09-2012, 05:38 AM
  #392
UNDER PRESSURE MOD
I see what you're saying, and maybe someone has a picture of the backside of the caliper they can share, but it looks like they are a mirror image top to bottom, including where the brake line goes in to the caliper. See the blue item in the hole, I'm wondering if you just move that one side to the other depending on which side of the car it goes on.
Again, if someone has a picture of the backside of the calipers that would help. Mine will be here this afternoon and I will take pictures to help clear up some confusion. It would make sense from a cost standpoint to make just one caliper that would work on either side as opposed to having to manufacture two different, side specific peices. It's kind of like our cylinder heads and gaskets, there is no left or right one.
Old 08-09-2012, 08:12 AM
  #393
Please post up and let us know!
Old 08-09-2012, 09:13 AM
  #394
UNDER PRESSURE MOD
Well, I figured out that there is a definite difference between left and right. So I checked Amazon and the correct pair is parts # 172-2287 and 172-2288. The problem is the picture they have for 172-2287 is what looks like a gasket set to a transmission pan and filter, hence why I didn't buy it.
So I talked to Amazon help desk, and explained it to them, and they agreed it was a misleading item description, so they authorized a paid return of one of the calipers, and I proceeded to buy the matching one, which is actually $25 less than the other one for some odd reason.
So I got both calipers to my door for a total of $227.93, and since their wharehouse/distribution center is in Delaware, and I'm in Pennsylvania, it'll be to my door by Monday.
Old 08-13-2012, 11:19 AM
  #395
Well crap, since it was posted that amazon had them in stock they have since gone out of stock. I didn't jump on it fast enough.
Old 08-13-2012, 06:02 PM
  #396
UNDER PRESSURE MOD
I got lucky and jumped on them instantly considering they were so much cheaper than anywhere else. I haven't even thought about what rotors I'm going to run or pads, but I knew that they wouldn't be around for long.
Old 08-13-2012, 08:45 PM
  #397
Empatho's Avatar
I noticed the same thing so I was a little weary about ordering it, but then I said f-it and I just ordered it because it does have the right part number.
I picked up the last 172-2288 that amazon had for $126 they had another one for $160 but it did not last long either.
Old 08-15-2012, 09:46 AM
  #398
Killer_Z's Avatar
after looking more at the yellow calipers that are shown. if u look at the mounting bracket its actually different on each side. so you would still need a left and right one, switching the screws wouldnt work. i'm wondering if theyre just using the same picture for both left and right.
Old 08-20-2012, 11:25 AM
  #399
Where is everyone getting their stainless brake lines from for this swap?
I tried looking through the threads but I might have overlooked it...
Old 08-20-2012, 04:16 PM
  #400
Actually...this looks to be it: http://flynbye.com/catalog/i209.html
Quick Reply: CTS-V Brake Install w/ Pics
