where do you buy new 93-02 bump stops?
[QUOTE=xXxSilveradoxXx;11750917]Energy Suspension might have some.
couldn't find it in there.
Last edited by Major_Lee_Slow; 06-14-2009 at 09:24 PM. Reason: Link to Non-Sponsor Site
If your '96 SS uses the short black ones along with the aluminum spacers like my '00 SS your pretty much out of luck getting them new, I couldn't get them from GM(discontinued) and had to get a used one. Make a post in the Parts Wanted section, that's how I got mine.
If your looking for the longer tapered type the situation isn't much better, check this thread https://ls1tech.com/forums/suspensio...r-bushing.html
First two products on the top of page.
http://www.hawksthirdgenparts.com/di...ndunits_2.aspx
The short red ones look useless. Too stiff.
How would you describe the firmness of the compound? Did they make them really soft or what?
I haven't used those aftermarket ones, I got bump stops from a Chevy dealer only a couple months ago, I guess they were discontinued only recently. I think the reason those are so expensive is because of the metal used on the base.
![Lightbulb](https://ls1tech.com/forums/images/icons/icon3.gif)
So you're looking at about $52 to do exactly the same thing!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Better yet just buy the bumpstops. And with a slight modification to either the bump stop or mount they bolt right up! This is you best bet, unless you mount some bump stops(koni 55mm I think) on the shock shaft like JasonWW did!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Now that I'm tubbing the rear of my car, I'm looking for some adjustable height bumpstops. Something I can adjust up or down to really maximize the suspension travel. I haven't fount anything yet, unless you count the pnuematic bumpstops used on offroad race trucks, but they are rediculously expensive. I'm thinking more like a foam tapered stop molded to a threaded rod for 10 bucks. No one seems to make anything close, though.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
The only guy I know with a tubbed rear (and front) for lowering purposes is Kenny. Check it out here.
https://ls1tech.com/forums/tools-fab...camaro-pics.html
All I've got done so far is clearancing the trans tunnel. My torque arm was touching the parking brake bracket. Now that this is fixed, I can go down another 1/2". Now I'm touching the tank.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![](http://img.photobucket.com/albums/v335/JasonWW/Air%20Suspension/IMG_1106b.jpg)
As you will see on Kenny's car, there are a ton of things that have to be done including getting the gas tank out of the way. Once you get down to a certain point, everything suddenly jumps into your face.
