Eibach Pro-kit sits too low???
Hey everyone,
I have the Eibach pro-kit springs f/r on my 00 Trans am, but it just sits too low. I have looked up pictures of trans am's with the pro-kit springs front and rear and they sit higher. My tires do not rub, but with hooker lt's my Y-pipe is close to the ground, I'd say about 2" under the drivers seat. I have learned to drive with it but i would like it to be higher.
Could it be the springs? or the shocks? The shocks are Blue Tokico's. I took the wheel off my driver front and called eibach to make sure they were pro-kits, the numbers match up and they are. I called Tokico as well and they said the shock I have are factory replacments... so why does it sit so low? and what should i do to raise it? Or is this just how the pro-kit sits on some cars?
Check out my picture and see if anyone could give some input. wheels are 17" all around with 275/40/17 on all.
LS1TECH Sponsor
Because that's what happens, not two cars sit exactly the same. Those springs do tend to be a little lower on average than mine are for example. There is nothing "wrong" here, it's just a Pro-kit thing, and it's the reason that springs estimate drop, don't guarantee it. The exhaust drags because you are lowered and down more than I like, and you have pipes that hangs lower to start with.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
thanks, a little low for my taste and it make the wheels look more tucked in. i'd like it a little higher, some 315's in the back and maybe a small spacer in the front(still maybe) and then i'd be happy with the stance
Usually pro-kits tend to sag in the rear which makes the front look higher.
But to raise the car, yes you would need a spring with a less of a drop. Stranos and BMR springs usually lower our cars the perfect amount where it's not too low or there's not tons of wheel gap. Do a search on here. There's a thread dedicated to cars with strano springs and there are a lot of cars also running BMR springs on here. Shouldn't be too difficult to find pictures
click sig link. not sure which springs, but stock suspension otherwise. i think it sits way too low. i hate it. i have a set of stock springs to go on it, but i've been too lazy to swap them. i don't think there is anything wrong with your car. i believe mine are sportlines.
Almost the entire website is against pro-kits, yet you installed it anyway, now your exhaust is 2 inches off the ground, and you want our opinion now. You
Yours sits the same as mine, certainly too low for my taste, but it's something the previous owner installed. When I get the funds to correct it, Strano's springs will be going in.
Once I have a better money flow i will buy some stranos and sell the prokit
I personally think the main problem is the exhaust. If you don't want stuff dragging at full suspension travel then make sure you set it up that way. Prokits obviously don't help, but no matter the spring unless its super duper stiff they all have the same suspension travel at full compression. Something's gotta give... there's no miracle solution to it all
