How to get low!
This makes it seem like most springs drop more than advertised, but in most peoples experiences, which have dropped the most?
Thanks guys, and sorry for the pure noobness in this area.
Added a pic of the stealth just for giggles
You should definitely get some better shocks though, since your stock ones won't keep up long with such a drastic spring/spring rate change. The best, cheapest way to go are with some KYBs. I have the KYB AGXs up front and I love them. But, you'll be spending a little more than $500. But post a Want To Buy thread and try to find some used springs. Good luck! Heres a pic with the sportlines on stock shocks (rode like ****, handled good and looked great)
[IMG]
Uploaded with ImageShack.us[/IMG]And with the Koni 4/4 and H&R sport springs.(rides great still stiff and awesome handling.)
[IMG]
You should definitely get some better shocks though, since your stock ones won't keep up long with such a drastic spring/spring rate change. The best, cheapest way to go are with some KYBs. I have the KYB AGXs up front and I love them. But, you'll be spending a little more than $500. But post a Want To Buy thread and try to find some used springs. Good luck!Trending Topics
Whats your ground to top of wheelarch measurements? I'm at 26" front and 26.5" rear. I had my front suspension apart the other day and noticed the top of the balljoint (stock control arms and balljoint) had made contact (on both sides) with the top of the fenderwells. The tops of the balljoints looked 'ok', not damaged, but there are marks were they had hit the fenderwells. Maybe I hit a pothole at some point. Drives fine and don't feel like anythings bent and no vibrations thru the steering wheel.
Installed
Quick pic out the office window. I have them set at 25.5" to the well at the moment and I am digging it. Tucking the tire a bit with some neg. camber
chaman..just gtfo!!! Jk, thanks a lot for the pics, and those pic made me pretty jealous..the rims are phenomenal..that is a straight tie with Whytry in my book..both very nice rides!
Whats your ground to top of wheelarch measurements? I'm at 26" front and 26.5" rear. I had my front suspension apart the other day and noticed the top of the balljoint (stock control arms and balljoint) had made contact (on both sides) with the top of the fenderwells. The tops of the balljoints looked 'ok', not damaged, but there are marks were they had hit the fenderwells. Maybe I hit a pothole at some point. Drives fine and don't feel like anythings bent and no vibrations thru the steering wheel.Ill have to measure the height and get back to you tonight.
Thanks for the compliments also guys. My set-up is more towards looks since its just a daily. I have dropzone springs, factory replacement shocks (the better quality ones) heater hose mod in the rear and upper shock mount mod (cut about 3/4" off the upper spring seat). Rides a bit rough but not as bad as I thought it would with what I did. No scraping unless the speed bumps are pretty huge then I take it at an angle.
