outer tie rod ends, best replacement?
Old 09-08-2011, 08:33 AM
FocusVince's Avatar
Question outer tie rod ends, best replacement?
I found out while getting new tires on my car that my tie rod ends (outer) are worn out and on their last leg. Does anyone have any suggestions on the best (affordable) replacement? Also how do you change them yourself? I got to save money considering the money I just dumped on new tires lol.
thanks
Old 09-08-2011, 08:45 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I personally like to use Moog stuuf, from the quick search I just did it looks like Moog part number ES3238RL would be a good option for you.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 09-08-2011, 08:46 AM
mike171562's Avatar
Moog
Old 09-08-2011, 08:51 AM
FocusVince's Avatar
I'll have to look into those then, are they hard to install? I did a search on how to do it but I didn't quite understand how to do it.
Old 09-08-2011, 11:13 AM
sjsingle1's Avatar
loosen the jam nut.......and screw off.......get new .....screw on.....tighten jam nut........so easy a caveman can do it
Old 09-08-2011, 11:20 AM
LS14EVR's Avatar
Moog!
Above will get one end off. The other you need to remove cotter pin, unscrew castle nut, then use a pickle fork, or smack with hammer to seperate.
At lease that is howmost tie rods are.
Old 09-08-2011, 11:48 AM
BMR Tech2's Avatar
Also understand that you will need an alignment immediately after you've replaced them. The proceedure listed above is what I've always done with tie rods.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-08-2011, 04:28 PM
leadfoot4's Avatar
Moog, Moog, and nothing but Moog!
Old 09-08-2011, 07:48 PM
FocusVince's Avatar
I knew about the front end alignment, I think it needs it anyways. Are there any specific places to get the moog rods??
Old 09-08-2011, 08:40 PM
libertyforall1776's Avatar
Question
AFAIK, the OEM ones are sealed, but the Moog ones have a Zerk grease fitting -- so are the greasable versions better for any reason?
Old 09-08-2011, 10:18 PM
67SS&99SS's Avatar
greasable are definitely better. being able to grease the joint means that you can increase its life.
Old 09-09-2011, 12:06 AM
SVThuh's Avatar
Moog is as good as it realistically gets.
Old 09-09-2011, 01:22 PM
leadfoot4's Avatar
Any GOOD, local parts supplier will be able to get you Moog parts. If not, there's always mail order...
Old 09-16-2011, 10:20 AM
Syris's Avatar
You can also count the amount of threads showing on the old tie rod and use that as a reference when installing new ones. This will allow you to put your alignment close to what it was before replacement.
Quick Reply: outer tie rod ends, best replacement?
