Torque Arm....tunnel brace mounted.....which has the best clearance......
I'm lowered so I need the one that tucks up the best......
Also....money really isn't an issue. Which is best for me. Roll racer only. No drag racing.
Its getting a 200 shot of spray soon, later the Modular Turbo TT kit........so I want something that will NOT need upgrading later.
And do I get an adjustable or non-adjustable......?
EDIT: Forgot to mention I'm putting in a 4L80E......
Hello,
For a set up that tucks up the highest and offers the most clearance, I recommend a transmission mounted torque arm with a torque arm relocation kit.
This set up will handle all the abuse you can put to it so you won't need to change or upgrade down the road. I posted three links below, two links for the torque arm and relocation kit and the third link is for a build we did that has tons of pictures of this set up and the clearance.
www.umiperformance.com/2205
www.umiperformance.com/2207
https://umiperformance.com/catalog/i..._page=02camaro
Please let me know if you have any questions. Thanks!
http://www.coloradospeed.com/bmr-tor...s1-p-7566.html
or
http://www.coloradospeed.com/bmr-tor...s1-p-7567.html
AND
http://www.coloradospeed.com/bmr-ful...rd-p-7553.html
http://www.coloradospeed.com/bmr-tor...s1-p-7576.html
andf
Aftermarket performance parts are usually designed around a stock setup. i.e. 1-7/8 headers with a 3" y-pipe is designed to fit to a stock exhaust and vice versa on a 3" exhaust. While mfg's try to make accomodations to work with a setup that may not be stock, it's impossible to cover all bases. Each car is different also even though it may be the same make and model.
Unfortunately UMI does not have that relocation bracket available. You need this:
andf
andf
