Afco Rear Coilover Conversion w/ Madman Shock Relocates on 2001 Camaro
Well I did the Afco Rear Coilover Conversion w/ Madman Shock Relocates on my car. Just wondered who else has done this and how you guys think this turned out? Let me know what you think.
![](https://img849.imageshack.us/img849/6590/acib.jpg)
![](https://img833.imageshack.us/img833/30/0ghx.jpg)
![](https://img571.imageshack.us/img571/6893/icw4.jpg)
![](https://img7.imageshack.us/img7/1364/nho2.jpg)
![](https://img547.imageshack.us/img547/1971/w8ex.jpg)
![](https://img27.imageshack.us/img27/6792/cytn.jpg)
![](https://img196.imageshack.us/img196/5682/mdpy.jpg)
Im interested as well! Looks great. Im wondering all what was required to fit them (haven't looked under the back end of the car in a while, damn school). It looks like the lower mounting point was added?
Also, if you don't mind posting overall cost thatd be helpful too!
Here are the prices off the top of my head. Prices from Madman change sometimes.
Rear double adjustable Afco's that are Madman valved $362 each
Chrome Afco springs about $40 each
Shock relocates (have to get welded on) from Madman around $45/pair
Coilover hardware kit (top and bottom pieces that go on the shock for the spring) not sure if it was $50/each or $50/pair
Let me know if you have any questions. I think these were all the parts I needed to do this.
Looks good man, I currently have rear DA afcos on the car and i'm converting them to a coilover this winter.
Just wondering who makes the ARB set up like that? looks like the phb is attached with it as well?
you have any photos by the top of the shock where you have to weld in the relocates?
On this first video I got out of it after the 1/8th mile because I was running to fast at the LS Fest for not having a roll bar or cage.
Here's a video from outside the car at the LS Fest and again I got out of the throttle after the 1/8th mile.
Yes I do street drive the car. I've put almost 1,000 miles on the car this year in the only 3-3.5 months that I've been able to drive the car. I didn't get the coilovers and the rest of the stuff installed until sometime in May and then I broke my transmission the first pass back to the track on July 3rd and my car sat for 6 weeks.
Where you bolt in the top of the coilover is the factory bolt in location. The shock relocates gets welded onto the lower shock mount location. You can see it in the 2nd, 3rd, and 5th pictures where almost a piece of metal is added onto the the lower shock mount location. All it pretty much is a square U shaped piece of metal added to the lower shock mount location.
Oh and another thing I forgot to mention I don't think you could use the factory rear sway bar or an aftermarket anti roll bar that is like the factory one with the coilover conversion because I think the coilovers are in the way to where it bolts in.
