Right now we run Moog and have had good luck with them for a few events. We are working with Hoosier as well on using their new hubs.
I've heard Moog has a little better luck than Timken and SKF for some reason. Hoosier has some amazing custom stuff, I raced against these guys and they made my setup look like dirt. Incredibly nice people as well, their shop isn't 10 minutes from where I go to school and I could walk right in and ask questions. I'd definitely look into the custom products they make, a little pricey IMO, but ya gotta pay to play
Been using this setup for 2 years now. I have one of the earlier sets. It's awesome, hubs last forever. Proven on any track driven corvette. We also used the x-trackers on the old Grand Am/PWC corvettes with zero issues. I was previously chewing through 3-4 sets a summer. Cheaper than the Hoosier hubs.
But the SKF race hubs aren't an f-body fitment, they are a Corvette which is 3 bolts vs. the F-body square flange.
I carry and use the SKF race stuff on my Z06, but it's not a fit for the F-cars. Which is why we also carry the Hoosier Performance Engineering hub set too.
__________________ www.stranoparts.com --814-849-3450 Results matter. Talk is cheap. We are miles beyond the success anyone else has had with the 4th gens, and C5, C6, C7 Corvettes,
Ahhh, THAT'S the expensive version I was talking about. They took the SKF hubs for corvettes and modified them for Fbody guys. And then there is the Autozone specials that you can stock up on.
No, they didn't. The HPE ones are a spindle that uses actual wheel bearings and a custom hub (and it retains ABS too). They aren't cheap, but you can see why when you look at them.
Wheels and tires are in from Strano Parts. Forgestar F14's 18x11 with Rival S 315's.
If you get the chance could you weigh that wheel before installing it? Would like to see if I would be shaving off any unsprung weight by going with F14's in that size even though I'll be going from 17's to 18's.
Yeah, not sure which of the OE style replacements Boss002 was using, but his hub completely separated at an event, sending the wheel, caliper and part of the hub off into the paddock.
Are these ESP legal now or is it just a "Run it until somebody bitches about it" move? I vaguely remember seeing a post on FRRAX about trying to get a letter drafted up to protest it an allow us to use aftermarket hubs without a penalty since they aren't lighter or change the geometry of the suspension and it's a safety issue.
What do you current wheels weigh? Those are right about 22 pounds in that size.
Isn't there someone (forgot his name/username) on frrax.com machining up conversion adapters so that we can use the above SKF Vette 'race' hubs on our cars' spindles??
No idea, I don't go over there anymore. But the SKF stuff plus adapters while cheaper to start are also not serviceable so the next time you end up at like costs, and the 3rd time you are just spending more.
Yeah, a funny title so it's not the easiest to find, this is some info about it, not sure who actually makes the adapters though: So I bought a shirt........
Looks like the hub's are 350 each and both adapters are 450, if you are able to get the guy to make another batch that is. So total cost is 1150 for the C5 hubs with adapter brackets. Or 1400 for the Hoosier PE 4th gen hubs.
