UMI Performance Suspension Over Haul - 1999 SS - Lots of pics!
Old 03-01-2016, 07:28 PM
  #281
RAMPANT's Avatar
Originally Posted by 79_T/A
Been using this setup for 2 years now. I have one of the earlier sets. It's awesome, hubs last forever. Proven on any track driven corvette. We also used the x-trackers on the old Grand Am/PWC corvettes with zero issues. I was previously chewing through 3-4 sets a summer. Cheaper than the Hoosier hubs.
Yeah, I was willing to buy the HPE units, but they were in transition to a production unit forging and could not be promised on time. So I bought the SKF from them.
  #282
M4N14C's Avatar
Originally Posted by Sam Strano
What do you current wheels weigh? Those are right about 22 pounds in that size.
That's damn light for such a big wheel. I currently have the stock chrome 17's that my car came with from the factory. Remember reading somewhere that they are around 20-21lbs. Looks like for roughly the same weight I get lot more rubber on the ground and clearance for a big brake kit.
Got any specials coming up soon?
Old 03-01-2016, 10:57 PM
  #283
sjsingle1's Avatar
No, they didn't. The HPE ones are a spindle that uses actual wheel bearings and a custom hub (and it retains ABS too). They aren't cheap, but you can see why when you look at them.
http://www.stranoparts.com/partdetai...=219&ModelID=7
I did not know about these....saving my pennys as of right now !!!
Old 03-02-2016, 06:56 AM
  #284
smitty2919's Avatar
I believe you can also just keep the receipt for the Timken hubs from autozone, when they fail just swap out for a new one. Just becomes a nuisance doing this.
Old 03-02-2016, 12:48 PM
  #285
RAMPANT's Avatar
It is not only about the replacement, but potential harm to the car if you are racing.
As above a complete failure and front wheel falls off. As in my case a move to a fixed caliper IE CTV or Wilwood. If the bearing is loose, you will get pad knock back and a possible brake failure into a corner. We were seeing 168mph at one track. I do not want to go off roading at those speeds. A floating caliper can accommodate some bearing movement, fixed will not.
GM even puts software in the V cars now that taps the front brakes to close up any pad knock back to account for this.
Old 03-02-2016, 01:26 PM
  #286
LS1TECH Sponsor
Sam Strano's Avatar
They are pretty well made to order, and not exactly priced out of this world to start with, so the short answer would be, probably not, no.
__________________
Old 03-02-2016, 01:28 PM
  #287
LS1TECH Sponsor
Sam Strano's Avatar
I would say the "adapter" must have to push the hub out, which changes the track width and scrub radius where the HPE stuff won't.
__________________
Old 03-02-2016, 05:44 PM
  #288
79_T/A's Avatar
You would be 100% incorrect. Does not change track width, or abs function. Plug and play.
Old 03-03-2016, 01:53 PM
  #289
LS1TECH Sponsor
Sam Strano's Avatar
Like I said I haven't seen it. Got a link? I'm not sure how you'd adapt a 3 bolt hub to a 4 bolt knuckle without something to match them. Not saying it can't be done just can't picture how.
__________________
Old 03-03-2016, 02:07 PM
  #290
RAMPANT's Avatar
I showed the pictures above.
https://ls1tech.com/forums/suspensio...l#post19167629 Post 266
Works well. Some major machining and quality work. that said, if the HPE units were available when needed, I would have bought them. My Wilwoods bolted on and no changes to track width. The ABS worked great till I cut an ABS wire on the rear axle. The pins did need to be swapped on the front harness as well, other wise plug and play.
The small bolt holes are for a brake duct plate. The four larger ones are for stock hub mount locations.
Old 03-03-2016, 02:15 PM
  #291
79_T/A's Avatar
www.rrsusp.com
Uses a cnc machined billet steel adapter. Corvette hub is much shallower than f-body. Adapter fits tightly to corvette hub, gets bolted together. That assembly bolts up just like a factory f-body hub. When I was looking for a hub solution, the Hoosier products were unproven and they weren't able to deliver. These adapters had already been in use out west on some NASA AI race cars. Having said that, the Hoosier products looks amazing, and it's a great design. Had they been able to deliver I would have heavily considered using them. I was just tired of pad knock-back after switching to a fixed (Wilwood) caliper.
  #292
smitty2919's Avatar
I can see how no they adapted it without any additional track width. Just clocked the 3 hole bolt pattern within a 4 hole bolt pattern.
Old 03-03-2016, 03:14 PM
  #293
Corvett z07's Avatar
I already posted this but no one seems to have seen it...https://ls1tech.com/forums/suspensio...ght-shirt.html
It shows pictures of it much better.
Old 03-03-2016, 03:38 PM
  #294
LS1TECH Sponsor
Sam Strano's Avatar
No, I didn't see it. Now I get it. Cool part. By they way, I have the SKF hubs too, $350 each. Listed on the site under Corvette.
__________________
Old 03-07-2016, 03:53 PM
  #295
camarokid91's Avatar
aahhahaaha that shirt rules and reposting that cracks me up. Shame I'm a vette bro now.
Old 03-15-2016, 12:36 PM
  #296
UMI Performance's Avatar
A few updates. Our new power steering pump came in from Turn One today, we are also getting our rack rebuilt. We will be installing the new pump this week.
The new American Racing headers are on and fit great, extremely nice product.
Old 03-15-2016, 03:22 PM
  #297
dailydriver's Avatar
NICE! I take for granted that is your latest, triangulated/reinforced ROAD RACE k member?
Those long tubes and y pipe tuck up nicely.
Turn 1 is going to have to send me some of those new style stickers for my pump.
Old 03-15-2016, 07:44 PM
  #298
LilJayV10's Avatar
Where are you getting your rack rebuilt at?
Old 03-16-2016, 07:50 AM
  #299
The car does have our road race k-member on it, it's about two years old though. It was the prototype for the new alignment locks that prevent the a-arms from moving in the slots. It has proven well!
I'm pretty sure we are having Turn One rebuild the rack as well.
Old 03-16-2016, 08:48 AM
  #300
UMI Tech's Avatar
I talked with Junior at Turn One and they are well versed in tuning that rack. They don't do any part upgrades in it, just a high quality rebuild using skilled technicians and premium parts.
Quick Reply: UMI Performance Suspension Over Haul - 1999 SS - Lots of pics!
