UMI Performance Suspension Over Haul - 1999 SS - Lots of pics!
Old 04-05-2016, 09:23 AM
  #321
UMI Performance's Avatar
These will mount in the rear as a true coilover yes, bearing to bearing with a reinforcement plate up top and a rear end mounting bracket. It will require two holes to be drilled on the rear end shock mount for support. There's pictures of this mounting system with our Viking package seen here: http://umiperformance.com/catalog/in...roducts_id=783
Double's might be some time out as we still have some work to do. There's some packaging issues and other things we are still deciding on. We are so happy with the the way the single monotubes worked we feel they will do the trick. The rebound adjustment is very good on them and we have the compression fixed right where it needs to be.
Adjustable upper a-arms are getting closer. We have a cool new lower to go with them.
Lots of good stuff for the 4th gen happening here
Old 04-05-2016, 05:34 PM
  #322
79_T/A's Avatar
Patiently waiting on those upper arms. Anything you can share about the new lowers?
Old 04-06-2016, 08:42 AM
  #323
Yep I can. The guys are still working on this right now so let me shed a little light on it.
So as many of you know adding positive caster using just an upper a-arm will move the spindle pin back slightly. It's pretty minimal and not necessarily an issue. However when running a larger tire such as a 315 on an 18" wheel in the front room is valuable to prevent rubbing. In order to run a nice amount of caster, if more caster is desired, we are moving the lower ball joint forward to help offset the upper a-arm. Since the spindle is so tall it takes moving the upper a decent amount to get a few degrees of positive caster. The upper adjustable a-arm will still work with stock lowers and should give anywhere from 5 to 8 degrees of positive caster with adjusting. With the lower we intend to install the new lower and the preset adjustable upper and immediately get 7 degrees of caster while maintaining a centered spindle pin.
Old 06-06-2016, 03:01 PM
  #324
smitty2919's Avatar
Any updates overall?
Old 06-07-2016, 08:45 AM
  #325
Yep. I have been updating the other thread and I think getting my two threads mixed up.
We have used the car in 4 events already this year and it is doing great.
Now we are working on tuning up the roll center of the car. Similar to watts link but at a lower cost to build and more importantly to us right now is a quicker easier fix for the car the next event. We noticed immediate lateral grip when throttling out of a turn with the lowered roll center. This should soon be a affordable kit to work with your current panhard bar set up. Stay tuned.
Old 06-07-2016, 01:34 PM
  #326
dojob's Avatar
nice, looking forward to me details on this kit
Old 06-07-2016, 02:22 PM
  #327
smitty2919's Avatar
Someone needs to make adjustable front endlinks to corner balance an Fbody while offering C/O setups.
Old 06-08-2016, 04:57 PM
  #328
dailydriver's Avatar
NICE!
I may consider this as a 'stop gap' until I save up my pennies for either a Fays 2, or YOUR Watts Link (IF that ever happens??).
Will this kit be TOTAL bolt-on, or will there have to be cutting and welding involved just by the nature of where/how it's mounted???
Old 06-08-2016, 08:37 PM
  #329
UMI Tech's Avatar
Total bolt-on. Tack welding recommended as insurance (with big tires, aggressive auto-x, etc) but not required.
Old 06-08-2016, 09:22 PM
  #330
smitty2919's Avatar
UMI, you ever plan to run some 315 Hoosiers and really put a lot of these parts to the test? Assuming the hubs hold up
Old 06-09-2016, 08:24 PM
  #331
^^^They are currently only running in events which limit the tire compound/tread wear ratings (as you know), but yes, the Hossiers would be the ultimate 'stress test' for these products, assuming the HPE, or the other (forgot the name) hub conversion, as you've stated.
Old 07-06-2016, 01:12 PM
  #332
TX98Z28's Avatar
Now that we are quickly approaching the off season we have a few projects in the works. We took a little drive yesterday to see Sam at Strano Parts and let Sam drive the car, help with tuning and discuss some future product ideas. Same through the car up on his lift and we made some shock adjustments and discussed a few other things. We have some great ideas working together and some cool stuff coming soon we hope.
Completely of topic but what kind of lift is this? And price? This looks like a great compromise for space and money instead of buying a big ole shop lift. Also can you drop the motor with one of these, will it get high enough off the ground?
Old 07-06-2016, 01:47 PM
  #333
UMI Sales's Avatar
That's Strano's lift in his shop.
Craig
Old 07-25-2016, 10:47 AM
  #334
An update on Jerry's 4th gen from the Motor State Challenge this weekend held at Gingerman Raceway and autocross at the Tire Rack facility.
On Gingerman coming out of turn 10 the front right hub snapped in half, luckily it happened after the turn and I was able to bring the car to a safe stop off the track with damage to the car and driver as well as passenger safe. This was extremely lucky and could have been a lot worse! This really opened our eyes to the hub issues these cars have, we wear a lot of hubs out but this is the first we have broken one and it's becoming common.
We have been talking with John at HPE from some time about his hubs but never acted on it, $1,400 for a set of hubs can sound pricey but when you experience this type of failure you no longer blink an eye at that. HPE was at the event and we now have a set of their hubs coming to cure this issue. We were able to locate a factory hub from Autozone to finish the autocross part of the event, but the failure was in the back of my head at all times.
The accident also bent the C5 brake abutment bracket but a big crowbar and some redneck engineering allowed us to patch the car to finish the event.
Old 07-25-2016, 12:22 PM
  #335
dojob's Avatar
Glad you guys were safe during the incident and were able to finish the event as well.
Keep us updated on the hubs
Old 07-25-2016, 01:07 PM
  #336
TX98Z28's Avatar
Good to hear no one was hurt during the hub failure.
Old 07-27-2016, 08:00 AM
  #337
HioSSilver's Avatar
Nice....i moved my panhard years ago to get the roll centers better. A lowered car needs this to keep thr panhard level.
Old 08-01-2016, 09:16 AM
  #338
A few updates..
We have been battling some weird clutch issues in the car. We are on our 3rd clutch in less than a year. The current LS7 clutch was working good but the peddle still had a weird feeling to it, even with the adjustable Tilton throw out bearing and Tick adjustable master cylinder we couldn't get it right. Our stock transmission was having 3rd to 4th shifting issues like most do overtime so we are ordered a T56 Magnum built by Bowler Transmission. We also opted for the Quick Time bell housing hoping that maybe the stock bell housing was causing some alignment issues.
Well upon removing the old transmission and trying to dial in the new bell housing we noticed the starter bolts were loose, again. This is the 2nd time the bolts have just came loose on the starter. After some careful analyzing we quickly learned we had some cracks in our LS1 block. The cracks are just in the webbing but one crack runs into the the start bolt hole... we are assuming this is why the starter bolt kept coming loose. We sent some pictures to CRE, our engine builder and he said he felt confident we could just weld those. So that is our next step to prevent having to dismantle the engine and start over. At these this may get us threw the rest of the year.
These two pictures show the cracks we found:
Old 08-01-2016, 11:43 AM
  #339
HioSSilver's Avatar
That's because the ls7 clutch is a pile of **** and only belongs in dump trucks. The fingers move at high rpm then the release bearing can't get to them to release the disc. Put a real clutch in it.
Old 08-01-2016, 12:52 PM
  #340
blackandgold's Avatar
I wouldn't even put it in a dump truck a diamond or monster clutch would go well with this set up I think. Doesn't need to be anything crazy unless UMI wants a twin disc or something kewl.
Quick Reply: UMI Performance Suspension Over Haul - 1999 SS - Lots of pics!
