wheel jerking to the left or right after hitting a bump
Is this an issue with my control arms? I am also getting a clunking sound after putting the car in reverse and disengaging the clutch. (right when the car starts to move backwards)
LS1Tech Premium Sponsor
It could be an issue with a suspension item or the alignment could be out of whack too. The clunking noise you are hearing is more than likely the build up of tolerances in the rear end.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Is your rear end noisy or whine at all? If you have too much backlash in the rear end it will clunk. What kind of shops are you taking the car too?
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
I have the stock rearend and gears. I recently changed out the fluid. There is no real whine, but perhaps a little bit of noise when rolling to a stop. Hard to remember. Nothing substantial.
I initially thought the clunk was an issue with my tranny mount. so I took it to transmission shop. Second place was general mechanic.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Copy & Paste Moderator
When I had a steering issue like that, it was a worn ball joint.
Try this test.
* lift car so the front wheel is off the ground
* grab wheel at 9 o'clock and 3 o'clock positions
* rock/tilt wheel left/right in/out arc
* if it moves/slides independent of the steering wheel (helps having someone hold it), then its a loose tie-rod
* grab wheel at 12 o'clock and 6 o'clock positions
* rock/tilt wheel up/down in/out arc
* if it moves/slides independent of the steering wheel (helps having someone hold it), then its a loose ball joint
Try this test.
Surprised everyone missed this. It's bump steer. I'm assuming your car is lowered?
On a flat surface are your tie rods parallel with the ground or do they angle up (like a V).
I have the same peob. Also getting a bunch of noise from my BMR adj front LCAs. Want to look into replacing rod ends with a root joint. Or something.
Baer bump steer tie rod ends are the solution.
Just for reference I have BMR 1" drop LCAs, konis with strano springs. All with less than 10k miles on it. If the car is lowered enough than the angle of the tie rods get thrown off. They should be parallel to the ground. Mine look like a v.
Making your tie rods parallel with the ground won't help, if your control arms aren't. The control arms and tie rods need to be parallel with each other, ideally. Granted the lower arms should be parallel to the ground too. Keep that in mind. It is relative angles within the suspension to each other, not to the ground, and how they move together.
The problem you are overseeing is that under the arc of the movement of the control arm, the tie rod runs out of room to move, jerking the wheel back.
Think of it like a dog tied to a tree. A squirrel comes by and he takes off. Eventually the leash runs out of room jerking the dog back. That = bump steer
