check this out! loud clunk/thud noise
so i have been reading for a while now about this thud/clunk noise. havent really found much about guys fixing this issue. i have a 01 ss camaro. i too have this loud annoying noise coming from the rear. Every bump i hit. its loud. Well i checked everything out and i even switched out rear shocks and coils (had agx shocks and bmr lowering springs, i switched to QA1 shocks and stock coils) thinking this was it. It wasn't. So i got underneath the car last night again searching and searching. One thing i did find was the upper pand hard bolt was hitting the coil. which was stuck under my coil. i am going to test it out today and see if this helped my issue of the loud clunk noise. I just wanted to post this so other people can check it out and maybe it will fix this annoying noise on the passenger side. my car is still noisy since i have a aftermarket torque arm but my main problem was a thud noise from the passenger side. if this solves the issue ill post back on here to confirm.
Yea see i guess you could do that at the time i didnt have car jacked up. So your suggestion would work. Well i did get rid of the thud noise though. But my adjustable torque arm bolt was loose and that fixed another noise as well. So this problem i had could have been from this bolt.
