Ebrake hardware bolt won’t budge..
Assuming you are talking about a 98-02 F-Body... It's not an Allen bolt.
So, that's definitely probably part of your problem. (No amount of heat is going to help.) Putting the right tool on it will help a lot.This thread shows the clean part: https://ls1tech.com/forums/suspensio...s-e-brake.html
^ In order to get this out, you need an L-shaped screw driver. This thread, in post #4 shows the tools I use: https://ls1tech.com/forums/suspensio...placement.html
With the mini ratcheting screw driver and pry bar (to put pressure on the bolt and force engagement of the bit), the part should come right out. This is just one of those jobs, where you MUST have the special tool.
