DD with aftermarket K-Members?
I was just curious if they were for daily driven car? I want to shed some weight off my car but I didn't know if they were right forr me.
You know, I had this same concerns. I think there is a thread about this if you want to try the search function. Someone said that BMR kmembers were pretty strong and that there were no documented cases of them breaking in daily driven cars. Honestly I want a tubular kmember mainly because my headers scrape the stock one I have now
but obviously structural integrity has a lot to do with the choice to swap over.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I had a BMR K-member on a DD. And it broke on the left side at the weld where it ties to the lower A-arm. It was the cross tube the seperated and my wheel assy. pulled back into the wheel well. I had felt the front of the car drift at 70mph when it happened. Not a good feeling. There isnt a huge weight saving to warrent a K-member from any company to drive daily on the street. your stocker is not much heavier anyway. I have super low pipes on my car now and the only thing they scape is the street. Poly motor mount will stop most banging from exhaust systems if not all. If you are mech capable and have a lift or acsess to one the mounts wont take long to install. And are cheaper than a K-member. If you want a better handeling car do springs/shock combo and swaybars first. still cheaper and more rewarding.
well, perhaps that is the case. I only read one thread a while back about tubular k members and no one could say if they were breaking or not. I guess it's good that someone chimed in with personal experience ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
as far as my the exhaust banging on the kmember. It has to do with my damn kooks lt headers resting on TOP of the kmember. It's a stupid fit and no clue why my car has this issue
what broke on mine was the welds that connected the cross tube to the lower a-arm, which was a tubular piece also. You are not the only person that said this about Kooks. How bad is it, some have said a little grinding is nesasary to remedy that. If they are on the K-member, mabey you have a busted motor mount. I noticed when I replaced mine the engine sat a little higher.
I'm going BMR 'K' member
UMI rod end upper and lowers in the front
Umi LCAs and rod end PHB
and a UMI cross member mounted TA
Still putting the parts on, but i'm hoping for the best.
I'm not a DD but i do Weekend Warrior
Hawk
Hawk
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
the weekend warrior is a different thing, a DD is not a good idea. I liked the K-member, until it broke. The roads conditions are so much worse than any track,so the wont survive the hostile hiway. Just think about the pot holes, animals and quick turns your DD has to go threw on a daily basis.
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Even BMR no longer claims the piece is up to
street abuse.
Mine hasn't broken. But I don't take it for
granted, I baby it and inspect it.
"It's not the fall that kills you, it's the sudden
stop at the end".
street abuse.
stop at the end".
Thanks for the help. That tells me everything I needed to know. I guess I need to look else where to knock some weight off the car. Any Ideas????
Definetely remove the spar tire/jack, rear seats with seat belt assembly, empty out the washer fluid reservoir, remove AIR and EGR pumps (if applicable). Those combined items should equal around 60 lbs.
That's what she said...
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by xssive
The PA k-member also uses stock mount pedastals and as such, has a mouting plate for them that spans the two uprights on each side. This provides a ton in the way of bracing for those joints...
Hawk
