Which Rotors?
Old Apr 18, 2006 | 06:07 PM
Italiano99's Avatar
Default Which Rotors?
ok, I need new rotors because my stocks are warped and have already been turned. So Im thinkin of goin with a decent set of drilled slotted (don't know which brand yet) and probably pads.
What do you guys think of these?
http://cgi.ebay.com/ebaymotors/CHEVY...QQcmdZViewItem
I don't think I need calipers but will any pad for a 98+ camaro fit my stock calipers?
P.S. what is the average size of aftermarket rotors you guys use and what size are my stockies?
Old Apr 18, 2006 | 09:14 PM
Foxxtron's Avatar
Err..
Not to wear this out, but this subject has already been prematurely worn like many of the brake parts around here have. If you are looking for those benefits that the E-bay ad claim, you'll be surely disappointed as that's been proven otherwise.
My advice, just go for some quality OE replacement blanks such as Brembo or Autozone Duralast. The stockers are around 12.2" (can't exactly recall) and are more than good enough for even some of the most aggressive AX apps. Don't be suckered into the slick marketing of fancy rotors.
If you plan to stick with your stock system, go for quality blank rotors, maybe slightly more aggressive brake pads, use a higher performance brake fluid, and get your calipers, brake lines, and system checked and rebuilt/replace whatever is needed.
If you desire more info on brake tech, there's a sticky at the top of the thread.
Best of luck.
Old Apr 18, 2006 | 09:53 PM
Italiano99's Avatar
yea, thanks man. But how about Stopcheck? I heard that they are pretty good and they have a F and R set on ebay for 180 shipped.
Old Apr 18, 2006 | 10:02 PM
FrozenMonkey's Avatar
Blanks or high quality slotted rotors.
Drilled does nothing but ruin your pads faster and greatly increase the chance of cracking.
Old Apr 18, 2006 | 10:14 PM
VIP1's Avatar
Copy & Paste Moderator
copy and paste yet again......
Slotted and Drilling are only for looks.
Read this thread:
https://ls1tech.com/forums/suspension-brakes/435436-do-i-really-need-cross-drilled-slotted-rotors.html
Here is another thread:
https://ls1tech.com/forums/suspension-brakes/477787-need-help-explain-slotted-drilled-rotors.html
Old Apr 18, 2006 | 10:23 PM
chicane's Avatar
........My advice as well.
Old Apr 18, 2006 | 10:27 PM
Italiano99's Avatar
where can i find some good priced oe replacement blanks? I really want some silver zinc plated ones because I am upgrading to 18" rims and need something big and pretty behind them
Old Apr 18, 2006 | 10:32 PM
CrawlinWS6's Avatar
Import Patrol
I originally went with rototech, and they suck ***. ( warped my stock rotors withing the first 5k miles on the car. Bought new.) The slotted section was flush with the rest of the rotor in under 9months. I had bought brembo cross drilled and have had them for over 3yrs. Have well over 30 11.0x passes on them, and their doing great!
Old Apr 18, 2006 | 10:47 PM
chicane's Avatar
BTW..... the following link is the ultimate crossdrilled/slotted thread. Ever. Period. Too bad they deleted the Altimas.net thread...... it was like "56 pages of getting your *** handed to you." I'll see if I can dig up the original thread and post it. I just cant remember who it was that downloaded it to their own server just because it was the best thread ever.
Linky.... here.
Old Apr 18, 2006 | 10:58 PM
VIP1's Avatar
You can get Brembo OEM blanks from TireRack or Sam Strano (both are sponsors), but they aren't coated or painted. Some people also use AutoZone's DuraLast rotors, but those aren't coated or painted either. You could always buy a set and paint the non-swept area (where the pads don't contact).
Old Apr 19, 2006 | 01:59 AM
Italiano99's Avatar
thanks I might have to do that, but what do you guys think of the stopchecks? ive heard a couple of good things about them
