wheel hop
i had my first experience of wheel hop in my car yesterday and did not like it. What upgrade can i do for the Most improvement? LCA's, Torque arm? which will give the biggest improvement thanks
any reccomendations on what type, i was looking at the UMI's but am trying to figure out if i should get non adjustable or a chromoly double adjustable? i dont plan on lowering the car ever and am curious if the adjustable points make it weaker?
Relocation brackets will stop it
From speed inc.
http://www.ls1speed.com/catagory.cfm...%20/%20Chassis
Trac Tek
Relocation Brackets
Lowering your axle side rear control arm will increase traction, reduce wheel hop, and give you better anti-squat. These high strength brackets are made using 3/16" cnc laser cut and cnc formed cold rolled steel. Lowering almost any control arm up to 3". These are a must for lowered vehicles!
Available in both a Black or a Red Durable Powder Coating.
itemno description price buy
TT-CABB Trac-Tek F-Body Bolt-in Relocation Brackets - Black $89.99 buy
TT-CABR Trac-Tek F-Body Bolt-in Relocation Brackets - Red $89.99 buy
+ LINK TO THIS PRODUCT
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
From speed inc.
Trac Tek
Relocation Brackets
i have umi red non adj. and they eliminted all of my hop it was bad too, my radio bezel would come off, and mirrior would shake its *** off, if you are not planning on lowering it then thats it, if you are going to need relocation brackets
thanks for the input kinda funny they moved this thread here i wanted to here what the ppl in my area had to say but o well...The only reason i would consider getting the adjustables is because ive heard about centering wheels but i thought that had more to do with a panhard bar??
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Relocation brackets are what you are going to be looking for to help eliminate wheel hop. We offer a bolt on version(CAB002) and a weld on version(CAB001). They can both be found here http://www.bmrfabrication.com/F-bodyDrivetrain.htm The next thing would be set of lower control arms. I would recommend the standard non adjustable lower for your application(TCA001) which can be found here http://www.bmrfabrication.com/F-bodySuspension.htm The only reason we recommend using the adjustable lower control arm would be to fit a larger tire 28" or taller. Let me know if you have any questions regarding our products.
I would recommend a set of control arms and control relocation brackets as the step in eliminating wheel hop. Both items are very inexpensive and offer tremendous results. Also keep in mind wheel is terrible for the stock rear end and is a contributor to its failure!
If you have any questions please ask. Thank you!
Ryan
Don't mean to hijack, but I'm in the same boat as Dshag.
I have a set of BMR boxed lca's and was wondering should I get some relo. brackets before I install them or would the lca's cure the wheelhop alone.
