Need TIG welding help/advice
I'm using a 200A air cooled Weldcraft torch, DCEN, 3/32 collette & tungsten (2% red band), got the machine set on 100A , #8 cup, & my gas (argon) set to 20. What am I doing wrong? I am holding the filler rod 15* like I read that I'm supposed to but I can get the rod dipped in and out about 3/4 times and it always ends up getting stuck in the pool. I cant figure it out.
What is the base metal, thickness, and position of welding.... we'll go from there.
Thanks, letting the puddle melt the rod and not the arc is helpful, I'll give it a try tomorrow. But I dont have a pedal
So, what machine are you using?
I just have a little Miller Bobcat. if it is an SA-200 its going to be difficult tig welding with, at least easily. If you have a decent amount of welding, or may have in the future, you might be better off getting a dedicated tig machine. Scratch starting off an old generator is difficult for experienced tig weldors, for a begginer it will be like pulling teeth. You would be better off with a used syncrowave or such, anything that has high freq, coarse and fine adjustments and a foot peddle.This is what I use, a bit much for what you need i think, but just to show you this is an old machine and has hardly anything the new dynasty's have, yet welds great, it was $1100, with the bottle, nd water cooler off craigslist.
Yeah your machine is like a Cadillac compared to my welder. Its a SA-250, I have no problems scratch starting now after burning up 2 electrodes lol!
Here's some pics of the old machine I'm using.
If slight manipulations of the pedal were incorrect procedure, high end tig machines would never have a pulsing option... While it's true that the dip will control the heat, 99% of the time, most weldors will use the pedal to help the process, Im not talking abolut on off on, but a 5-10 amp (if that) change.
FWIW, I have never ever heard of a test failing do to using the pedal to control heat.
Working with an SA 250 is hard lol! If I could step on a pedal and get more amperage right as I dip the filler rod I think I could make a decent looking bead.
I have heard 2K plus is what I should look at paying for a basic AC/DC 220 machine with high frequency capabilities. 1100 is a steal IMO.
Hell, a brand new Dynasty 200DX, can be had for 2500 brand new, with more functions than you can shake a stick at, and in a small, portable package.
Just need to know where to buy stuff, if you go to your local welding supply, expect to pay $3300 or so for the same machine. I dont remember, I think IOS Indiana oxygen has the Dynasty for $2595 or something...
Budget... Ebay,craigslist
