Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#381
im just looking for replacements for my 16 stock rims on my 98 z. i would like to go a bit wider on back, but not sure. currently have 245/50/zr16's.
ive been trying to search it, but everyone seems to run the bigger 17 and 18 rims
thanks
josh
thanks
josh
#382
thanks
josh
thanks
josh
#383
I just wanted to get your opinion on my new set up for my 02 Z28
I got some 18X9 HPR5's and was planning on going with the BF goodrich KDW 275/35/18. Found them at costco for $215 installed per tire. Let me know what you think...
#384
#385
yeah, I went in and asked them yesterday afternoon. The guy quoted me there $215 installed. Ive had good luck there in the past with other cars so hopefully they wont screw up this one.
#386
God I hope it wasn't asked in this thread, but 20+ pages was too much.....
Will the c6 z06 replica wheels I just bought for my camaro fit on a corvette? All four are 19x9.5 w/ 275/35/18.
Just wondering, I'm having a really hard time deciding if I should keep them, or sell them and get the regular c6 wheels.
#388
#390
i want to put weld draglites 15X10 in the FRONT AND BACK. Is 10inches to big for the front, since the stock wheel is 9.5 i think they might be okay. i want to run bfg et radials 275/50/15 in the front and bfg 295/50/15 in the rear with a 7.5 backspace. lowered 1.6 in front, stock in rear. what do you think?
#391
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#392
TTII's 17x9.5 I know a 275/40/17 will work for front.
I was wanting to put the 17x11 TTII in the rear. Would I be safe w/ a
285/40/17 tire for that size rim?
The reason I say, is b/c I have 4 of these tires laying around w/o wheels on them, and I would love to have the 17x11's on the rear, but don't want to have to order new tires. So, will I be safe? Anyone have any pics of this size on their car?
Anyone else have to use a BFH or do any mods for this rim? Offset for the 17x11 is 45. The car is at stock ride height, and it has a moser 12 bolt if that makes any difference (95Z). I was hoping to be able to get away w/ the 285, to avoid and fender rolling mods.
#393
#395
hey, I have 18x9 evos 275-35-18s is that the only thing i can go with? I really want the widest available outback. Can anything smaller fit the front? Is it best I just go with matching on all 4?
#396
Sorry i have seen this here before but i cannot find it when i search.
1. Stock width on 2002 WS6...9.5"
2. Stock offset on 2002 WS6...50mm?
3. Wheel shops all say that 17 x 10" width will not fit up front. people here say they will? I do not any rubbing. I've been looking at the smoothies 17 x 10 with 36mm offset...will these stick out too much and look odd? I want to keep same size on all corners.
Thanks
Thanks
#397
Originally Posted by URNZONEBAIT
sorry for asking so can I put the 20x10.5 in front and 20X11 in the back. 1st will they fit ? If so what size tire to get? oh yeh the motorsport Z06 wheels.
#398
And a 275/35ZR18 is the widest you can go on a 9" wheel . . .
Small up front, sure, a 245/40ZR18 should work fine, although might look a little narrower than the wheel.
#399
Thanks
Thanks
2. Stock offset is 56 mm.
3. 10" wheels up front are pushing it. Although since you have a TA the fenders are a little wider than a Camaro. 36 mm IMHO will stick out up front. I have 38 mm offset 9.5" wheels up front, and they bearly fit under the fender lip. So adding more width, is going to stick out and a a smaller offset will make it stick out more.
#400
just a "double check and make sure question"... I'm looking to pick up some
TSW mondello's in an 18x9 +45 will these fit my 94' firebird with 275/35/ZR18 or any other recomended size.
