Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#561
So you think 315's would fit out back with a 10.5" wheel like the Z06 Motorsport? I'm just concerned with the safety of a 315 on a 10.5. I would certainly like 315's if at all possible (willing to do BFH/fender roll/etc), but am not willing to risk a blow out because I was retarded in trying to fit too big of tires on the wheel.
#562
A 315/35ZR17 fits a 10.5" to a 12.5" wheel
A 315/30ZR18 fits a 10.5" to a 11.5" wheel . . . . FYI
Seriously take advantage of all the great info at www.tirerack.com under the "specs" tab on the tire of your choice it tells you all sorts of good things to know.
#563
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
Too bad the GS-D3's don't come in 315/30/18
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
What's the biggest the GS-D3's and BFG T/A KDW2's come in?
#564
Thanks guys, I really dont wanna be stuck with a combo I dont like. If anyone has any 4th gen pics with oversize wheels please post and leave the specs, (offset, tire size ect..) THANKS AGAIN!
#565
Ok, I couldn't find any info on this. I put a turbo on my car, but it already had 4.11s is it, which is too big of a gear. I currently run 275/40R17s and I think 275/50R17s would be about like going back to 3.42s. Would they fit? BTW I have the SS chrome wheels from SLP.
#566
The Dick Harrell Supercars have an 18x12 wheel in the back with (I believe) 335-35-18 Michellin Pilot Sports. I dont know how good of a tire taht is. I've been a Goodyear **** for 18 years
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#567
#568
Originally Posted by Xsta Z 28
Your ABS won't be happy . . . . Due to the major diff in the tire OD.
#569
I had no idea this would be an issue. I thought if I changed the values in the HPtuners and programmed it in, that it would be ok. It was a crazy idea anyway I guess...
#571
I should be getting my wheels back next week from having them widened from 8" to 10.5" and I will be running 315-30-18's. I'm just wondering what size spacers i might need and/or possible longer studs. I was following the thread and i still feel somewhat lost when it comes to properly fitting tires.
#572
Up to you totally. I would look up the tire manufacturer's recommendations to be on the safe side.
#573
Originally Posted by Jakson
Wondering if these kind of firebird wheels will fit on the back of my Camaro. Id think they would be too small. Just asking because my friend has a set of them that we want to burn off. ![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
![](http://www.americancars-online.com/87%20firebird.jpg)
#574
#575
Best bet to determine the spacer size . . . test fit the wheels and measure . . .
I would look up the specifics the tire manufacturer recommends, for the brand tire you plan on using. For 315's, I have always read that 11" was the recommended width. I know you could probably get by just fine with 305's. Up to you totally. I would look up the tire manufacturer's recommendations to be on the safe side.
#579
Originally Posted by HIZPANICGUY21
WOULD I NEED SPACERS TO FIT 19x10'S 56MM..OR WOULD THAT NOT IT AT ALL..THANKS
Oh and FYI, when you type in all caps, one it is hard to read and two you are yelling at us . . .
Message board etiquette
