Billet Specialties Street Lite Direct Fit 15x10 rear Is avail for Shipping in 2 weeks
Dragwheelz.Com would like to introduce the Ls1/Lt1 Billet Specialties direct Fit Street Lite wheel. No Grinding is needed nor is a spacer for the rear. Front wheels are still In development and will be released at another date. I have 100 Pair that will be available for shipping in 2 weeks. Street Lite wheels are Made for The street and the Strip.
15x10 7.5" of Bs
Jobber is 359.99 ea. But please Email or Pm for the Ls1tech intro price
Street Lite Wheels:
• Accept mag shank lug nuts
• Can be used with 5/8in. racing studs
• Combine polished & machined finishes for an aggressive look
• Use bolt-on center caps w/ counter sunk allen screws
• Feature rotary forged aluminum centers
• Feature a 360˚ welded 2-piece construction
• Are super light weight (15x3.5 = 9 lbs. 15x10 = 16 lbs. )
• Use spun aluminum rims for high strength & superior run-out
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_front-1.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_rear1.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_rear.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_021.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_024.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_028.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_032.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_036.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_044.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_046.jpg)
Pics of wheel on car........
all oncar pics here. https://ls1tech.com/forums/wheels-tires/954169-car-pics-15x10-streetlite.html#post9737791
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4642.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4643.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4644.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4645.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4646.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4647.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4648.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4649.jpg)
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4650.jpg)
15x10 7.5" of Bs
Street Lite Wheels:
![](http://i112.photobucket.com/albums/n184/EliteCustom/Billet/Ls1/th_IMG_4659.jpg)
Im building a pro touring truck and im running 18's for the street and road course, but i will need a set of drag wheels. Im running LS1 rear brakes and i have a cut down 9" and i need the 10" with 4.5"BS.
i'm sure there will be. the price seems high to some i'm sure, but when they realize it's a true street/strip wheel and not a track-only wheel, they may start to appreciate it.
i'd buy a set, but my car has SOME wheels on it, and i've gotta allocate my funding towards the new motor.
I understand this is jobber price! What is the big secret about the ls1tech price? Just tell us.
I would like to see these wheels mounted on a ls1 4th gen. Also you might have more interest when you get the fronts ironed out.
For that price I can get Bogarts!
With the rising cost of material prices, You will see products going up in price also.
This wheel is not a standard Hoop as the 15x10 that is listed in jegs is. the jegs listed 15x10 accommodates anywhere from 3.50 to 7.50" of backspacing. As we all know those 15x10 w/ 7.5" of B.S. will not work on a ls1 brake setup, even with grinding.
So now we have the 15x10 Lt/Ls Specific wheel. Which if you look at the pictures you can see is not a regular standard hoop and was redesigned specifically for this purpose of bolting directly on with no grinding needed. A standard 15x10 hoop is readily available and cheaper( which does not work), this wheel was designed, and made specifically for this application which incurred some extra expense.
and ls1tech pricing is 319.00
