00 camaro SS **need front door speaker**
if anyone has a stock front door speaker in good working order i need one .. or a cheap alterative please let me know thanks
I believe any 6.5 two way or better should fit, but depends on how cheap you want to go. I know easily less than $50 for one can be had through local listings, just shop around. As for proper ohm rating and such, look to previous threads here, and they'll hell. I know white bird commenter ohm rating on factory speakers on one of the recent previous threads.
Ungrounded Moderator
The bigger issue is that you have component speakers in the doors (in a Monsoon system) and replacing with coaxial will force you to use only one of the two original channels, cutting your power in half again. Besides, component speakers will always sound better than equivalent coaxials.
From personal experience, I can highly recommend the 6.5" CDT components that Kee Audio sells. They have coaxially mounted component tweeters so they match the configuration of the factory speaker. They are 4-ohm but more sensitive than the stock speakers so there really is no loss of volume and they are much cleaner sounding and more durable.
Closed ex-Sponsor Account
I have these Hybrid Audio Imagine instock
http://hybrid-audio.com/imagine/
Here is some more speaker packages
http://shop.doubledmods.com/Generati...ages_c1349.htm
I have the original front door set in perfect condition from my 2001 SS, they were replaced when I upgraded the entire system at around 15k miles. Please PM me with a reasonable offer if interested...
