Did i screw up my amp/sub combo?
Okay i just got a stealth box so i went to install it and i get no sound to the sub. Here are the sub/amp.
Sub
http://www.crutchfield.com/S-98xpLX5...x?i=500SWR1042
amp
http://www.crutchfield.com/S-hIsvo2z...spx?I=575P5002
How would i wire this up so it sees 4OHM, it says they both can handle the load so i dont understand why i am not getting any sound, the amp is getting power and everything.
Sub
amp
did you wire to both voice coils or just one pair of them. 4 ohms is just wired to one voice coil. and 2 ohms is connecting the positives and negatives to each other from both coils
this is what i did, the sub comes with 2 "jumpers" that you can use, i wired up the pos from the amp to the pos of one coil then i used the neg from the amp to the neg of the other coil, i then bridged the other coil using the jumper
i am running a compaq laptop i dont have a headunit i use an lcd touchscreen. The amps are run off of a sound blaster external sound card, i am running another rockford p3002 i think that is powering my speakers. THe speakers sound great and the p5002 lights up so i know it is getting power, just the sub isnt working.
You can not get a 4ohm load from a DVC 4 ohm sub. You can only do 2 ohms or 8 ohms with that set up. Your amp MAY be able to handle 8 ohms but it will put out less power.
I would try to return it and get a SVC 4ohm sub if you can.
EDIT: Actually..
That doesn't make sense. He first makes it sound like the pos from amp went to one coil, and the negative from the amp to another coil......but then he says he bridged the other coil using a jumper.
But I still think he meant the "bridge" went from one coil to the other.
okay, my amp has 2 channels, to bridge it i connected one positive to one positive of the sub. I connected the negative of the other channel to the negative of the other coil on the sub. I then used the jumper to connect the remaining postive to the remaining negative coil. That didnt work, i then used the jumpers to connect the one positive with the remaining positive and the one negative to the remaining negative, that also did not work. Now i am stuck with it, i am going to try and wire up the coils to each channel of the amp but i have to wait until i get a piece to my laptop so i can re-install it.
Strange you got NOTHING out of either setup - the 2 Ohm load may have never worked if your amp immediately went into 'protection mode' -- did you try briefly cracking the gains/boost with the 8 Ohm load JUST to see if you can get any sound from it? Also, whatever you need to do to get the max preout level from your comp...
Is it possible you just don't know exactly how your setup works? You THINK your other amp that you are running is powering your speakers?
