Descreen or don't descreen
Old 07-28-2010, 09:32 AM
GoFastKid's Avatar
Default Descreen or don't descreen
Is it worth any extra HP or better flow to descreen the maf on a ls1? I noticed these don't snap out like the lt1's did so I didn't want to mess anything up by smashing this one out. Any thoughts? Bad idea?
Old 07-28-2010, 09:46 AM
2k2cam's Avatar
This topic has been discussed MANY times!
In my opinion, it's not worth it. Many people have done it though, and have not had an issue with it. I've seen a couple of things on my MAF screen that the air filter has not caught so I look at it as a final filter before it goes any further. It's your call.
Here is just one thread out of the many about this topic.https://ls1tech.com/forums/generatio...g-you-maf.html
Old 07-28-2010, 09:47 AM
SexyTransAm's Avatar
search or dont search?
Old 07-28-2010, 10:23 AM
King Nothing's Avatar
don't do it, not worth anything and if you **** up your maf you wont be happy
Old 07-28-2010, 11:01 AM
txmanincali's Avatar
I took the screen off of my LS1 and I've never had any problems with it. It sounds different when I rev it up though... you hear alot more suction if you will...
Old 07-28-2010, 11:12 AM
udienow's Avatar
I think its up to you. I have been running descreened for 2 years. No issues at all. But since the previous owner did it I have no idea if it did anything.
Old 07-28-2010, 11:22 AM
1998Z28LOADED's Avatar
I was going to do this until I looked at it and seen the screen had caught a bug or two, some pine needles, and one of those little helicopter things that fall off trees.
Old 07-28-2010, 11:31 AM
Latch's Avatar
Leave it alone. 0 gains from descreening.
Old 07-28-2010, 12:30 PM
chrs1313's Avatar
Incorrect...
bump stop mod doesn't worn either right?
or ram air kits?
if you believe pulling an obstuctuon from the intake path doesn't help maybe putting one in like a tornado will help?
all the little stuff adds up
Old 07-28-2010, 12:32 PM
chavez885's Avatar
Haven't had a screen in mine for about 6 years, zero issues.
Old 07-28-2010, 12:36 PM
LS1WS6dreamer's Avatar
Not gonna say it won't help, but I wouldn't do it. Something could make its way to the MAF. Without the screen it will go right through. Not a good situation.
People have found all kinds of stuff on the screen. Bugs,twigs, etc..
Old 07-28-2010, 01:18 PM
thunderstruck507's Avatar
several respected opinions have claimed it can conflict with the MAF calibration/tune
Old 07-28-2010, 03:32 PM
chrs1313's Avatar
only way this can happen is a huge hole in your air filter or it is not sealed up correctly...I bet at least 30% of the people who use a lid have bypass on the backside of it...it needs an extra strip of thick weatherstripping to seal it up nicely to the air filter...
removing the screen will help but it can tweak the tune so it should be adjusted or done before a tune, just like getting an 85mm maf to replace a stocker...
Old 07-28-2010, 05:05 PM
Latch's Avatar
Originally Posted by chrs1313
Incorrect...
or ram air kits?
Oh there are "gains" to be had from de-screening, the guy in this thread...
https://ls1tech.com/forums/texas-mem...yed-motor.html
...Gained a bolt into his motor that would have been stopped by the screen if he had one.
Old 07-28-2010, 06:54 PM
chrs1313's Avatar
bahaha nice try bud...
I guess everyone including me is screwed who is speed density tuned
also don't mention this to the carb guys!
Old 07-28-2010, 09:00 PM
1BAD98LS1's Avatar
I did it and had no issues. Been descreened since like 03. lots of trips to the track and thousands of street miles...of coarse I was going for a stock internal record and was trying to get every ounce of HP i could get..fyi
Old 07-28-2010, 09:12 PM
TheBlueKnight's Avatar
A stock screened maf will only flow about 800cfm if I remember correctly, as a descreened maf can flow over 1000cfm. Food for thought. And this thread has been started WAY to many times. It's the same every single time, half say do it, half say don't do it.
Come to think of it. I have been wondering if it's worth it to descreen your maf or not. I think I'll make a thread about it next week...
Old 07-28-2010, 09:32 PM
ShortChevy's Avatar
Wow, really? I guess sense I am speed density I should put a stupid *** screen in the bellows or something to stop things an air filter is designed and used for.
Old 07-28-2010, 09:46 PM
Latch's Avatar
If you're speed density then obviously that's a different story, but seriously, read that thread I posted... a bolt from the guy's aftermarket air intake came out and got sucked through the MAF and into his engine. Thanks but I'll keep my screen in!
My car's my daily driver, and I am not rich enough to replace a blown motor because something stupid like that happens. I'm just sayin. Why would cost-cutting GM spend the money to put a screen in the MAFs if all it did was obstruct airflow?
Old 07-28-2010, 10:11 PM
SAPS's Avatar
I believe the engineers intent was to straighten the air flow across the metering sensor. And for that reason, personally, I'd leave it alone.
