Removing my AIR
Old 06-14-2013, 05:45 PM
yukonblu's Avatar
Default Removing my AIR
Can someone give me some tips on doing this? I know where it is located, but what is the easiest way to do this?
Old 06-14-2013, 05:55 PM
ss performance's Avatar
Check out these
https://ls1tech.com/forums/generatio...gr-delete.html
https://ls1tech.com/forums/generatio...r-removal.html
https://ls1tech.com/forums/generatio...de-w-pics.html
https://ls1tech.com/forums/generatio...mount-faq.html
It's simple
Good luck
Old 06-14-2013, 06:00 PM
yukonblu's Avatar
Thanks... Sometimes im to lazy to do a search i guess lol
Old 06-18-2013, 05:15 PM
high n dry's Avatar
cleans engine bay up real nice!
Old 06-18-2013, 07:59 PM
TXZ28LS1's Avatar
Need some detailed pics... I get lost when the AIR snakes around in the engine bay and what it connects to.
Old 06-19-2013, 06:42 PM
yukonblu's Avatar
Ill do a write up on this since i'm removing mine. I know there are some on here but more detail would be nice.
Old 06-19-2013, 10:18 PM
TXZ28LS1's Avatar
Right on!! Looking forward to seeing it.
Old 06-21-2013, 11:20 AM
idle's Avatar
Assuming your EGR is unbolted... unbolt the two bolts on the exh. manifold. Reuse gaskets if necessary. Then put WS6store covers on the holes you just made by removing the lines. Then pull out the air line(there's a clamp on the back of your intake manifold helping to hold that line in place). You're done under the hood. Now crawl under your car (jack it up, I did atleast, the drivers front wheel) and unbolt the two bolts that hold on the little flap infront of the drivers wheel under the bumper. You'll find two bolts holding the pump on. Take it off and unhook(and cover) the connectors. That's it!
Old 06-21-2013, 12:23 PM
2000 TAWS6's Avatar
You'll need to get the codes deleted to keep the SES light from coming on.
Jon
Old 06-21-2013, 09:31 PM
yukonblu's Avatar
Well its on 02 so i don't have EGR
yukonblu's Avatar
Jon
Did this already, thanks
Quick Reply: Removing my AIR
