FTI Releases A New Torque Converter for 8L90E Transmissions
By -
If you’ve been wanting a high-performance converter for your 8L90E, FTI Performance now has your solution.
The latest automatic transmission from General Motors gives modern Camaros and Corvettes more gears than ever. Eight ratios makes for better driving performance without the fuel mileage penalty, as seen in some previous automatics. Now, FTI’s SRL9-3 series torque converter is available for this transmission for maximum performance at the strip. They can be built with stalls from 2,600 RPM to 4,400 RPM and torque holding with the triple-disc lockup clutch.
The SRL9-3 is a 9.5-inch converter made from CNC machined billet materials in the front cover, lockup piston, turbine hub, sprague race, and impeller hub. The impeller hub is further strengthened with furnace brazed and heli-welded fins and reliability is increased thanks to a triple bearing construction over the traditional washers seen in other converters. The Raybestos Powertrain friction clutch places can apply full lock up at full throttle for consistent performance and longevity. The SRL9-3 has seen testing and has proven itself with 25-thousand-miles of hard driving with quarter-mile runs in between, which is why they can not only give you the standard FTI Performance three-year warranty but are so confident they can also give you an additional lifetime warranty.
So, if you own a 2016 to 2017 Camaro or a 2015 and up Corvette with the eight-speed 8L90E, it’s time to give FTI Performance a call. Don’t know what you need for a stall speed or don’t quite know if the SRL9-3 is right for your car? Give their expert sales staff a call at 1-386-736-5816 to be sure you get the right stall converter for your street-strip dominator.
Want more information? Contact FTI Performance at 1-866-726-8358 or visit ftiperformance.com.
FTI Performance is a proud sponsor of LS1Tech.
