Pinouts and wiring diagrams
Old 06-20-2018, 07:39 PM
  #181
12SEC SS's Avatar
Originally Posted by chivobling
anybody have for a 98 camaro?
1998 Chevrolet Camaro V8-5.7L VIN G.pdf
Old 06-21-2018, 11:23 AM
  #182
CHIVOBLING's Avatar
Originally Posted by 12SEC SS
Thank you, much appreciated
Old 06-21-2018, 02:34 PM
  #183
12SEC SS's Avatar
Thumbs up
Old 06-28-2018, 01:07 PM
  #184
12SEC SS's Avatar
requested
2015 Chevrolet Camaro V8-6.2L VIN W.pdf
2015 Chevrolet Corvette V8-6.2L.pdf
2015 Chevy Truck Tahoe 4WD V8-5.3L.pdf
2015 GMC Truck Yukon Denali AWD V8-6.2L.pdf
Old 07-02-2018, 11:04 AM
  #185
t2true's Avatar
@12SEC SS, would you be able to post the diagram for the starter/ignition (from key to starter) of a 2003 Tahoe? Must appreciated.
Old 07-02-2018, 12:19 PM
  #186
12SEC SS's Avatar
Originally Posted by t2true
@12sec ss, would you be able to post the diagram for the starter/ignition (from key to starter) of a 2003 tahoe? Must appreciated.
2003 Chevy Truck K 1500 Truck 4WD V8-5.3L VIN T - Starting Circuit.pdf
Old 07-03-2018, 08:38 AM
  #187
t2true's Avatar
Thank you!!
Old 07-23-2018, 08:17 AM
  #188
12SEC SS's Avatar
Post
2005 Chevy Truck TrailBlazer 4WD V8-5.3L VIN M Engine Controls.pdf
Old 07-29-2018, 10:40 PM
  #189
LSXJeep's Avatar
If it would not be to much of an inconvenience I would appreciate a PCM pinout diagram for a 2003 Tahoe vin Z 5.3 flex engine 4WD Thanks for your time and consideration. I have fuel pulse but no spark so this may help to narrow it down. What a bummer not having the Jeep this summer. This is my post.
https://ls1tech.com/forums/conversio...g-jerking.html
Old 09-02-2018, 09:29 PM
  #190
Joseph Gonzales's Avatar
Default 2000 GMC Sierra Climate control pinout.
Would anyone have the pinout out for the climate control in a 2000 GMC Sierra 2500?
Old 09-04-2018, 09:36 AM
  #191
12SEC SS's Avatar
Thumbs up
Originally Posted by joseph gonzales
would anyone have the pinout out for the climate control in a 2000 gmc sierra 2500?
2000 GMC Truck - Air Conditioning - Heater Circuit (Heating and Air Conditioning).pdf
2000 GMC Truck - Air Conditioning - Compressor Circuit (Heating and Air Conditioning).pdf
2000 GMC Truck - Air Conditioning - Manual A_C Circuit (Up Level) (Heating and Air Conditioning).pdf
2000 GMC Truck - Air Conditioning - Manual A_C Circuit (Base) (Heating and Air Conditioning).pdf
Old 09-05-2018, 08:56 PM
  #192
Thank you.
I going to attemp wiring in an 05 silverado 2500 dual climate control into a 2000 sierra 2500. Hoping it works.
Old 09-07-2018, 11:51 AM
  #193
Originally Posted by Joseph Gonzales
Thank you.
Is there a specific plug diagram showing pinouts?
Old 09-15-2018, 08:40 AM
  #194
sagola11's Avatar
Default E78 ecm
E78 ECM can anyone tell me what pin to use for speed O and pin for Tach signal
Old 09-16-2018, 12:13 PM
  #195
sagola11's Avatar
Originally Posted by MWhite1955
12SEC SS, that did it man, you are a wealth of LSx info! Thank you sir!!
e78 ecm l96 6.0 can anyone tell me pins to use for tach signal and speed O???
Old 09-18-2018, 11:34 AM
  #196
CHIVOBLING's Avatar
would you happen to have the diagrams for a 1969 Chevrolet impala 2 door coupe 350 motor. Thanks in advance
Old 11-29-2018, 09:12 PM
  #197
355.4x4.ly5's Avatar
I really need engine harness diagrams for
2012 Colorado 4x4 v8
2008 Colorado 4x4 i5
Old 12-01-2018, 08:58 PM
  #198
Arqtec's Avatar
I am seriously lost here. I have a 2002 Camaro Z-28, hydrolocked the motor. Boom ! Bought a brand new ls3/525 hp crate motor. Installed it. changed out all the conversion stuff, knock sensors injector, front pulley assembly reluctor conversion devise,... has 342 rear end, built 4L60e tranny, 3400 stall, SLP CAI, tuned exhaust, It SMOGGED in California, thank god, The only problem I am having is High idle, severe warm up time to idle ( cam is 226/236/525/525 110 lsa) I had to switch out electronic TB 90mm for cable driven 92mm TB no adjustment left, drilled 2 hole in plate to try to get it to idle quicker runs rich needs air until it reaches closed loop by computer. I have the original computer from the ls1 tuned to run the LS3 motor, gauges still work and tranny shifts O.K.....Its crazy fast. any suggestions ? can I reinstall that electronic TB w/pedal and what about computer and gauges ? thanks in advance
Old 12-01-2018, 10:42 PM
  #199
Received 3,190 Likes on 2,492 Posts
Your computer is only set to run a DBC TB. Which TB are you running now?
Old 12-02-2018, 09:28 AM
  #200
jpndave's Avatar
You should probably start a thread for this and not derail the diagram/pinouts.
That said, is the fast idle stepper there and working? If you want drive by wire I'd consider a gen 4 computer/harness stand alone. Then this thread for pinouts/wiring.
Quick Reply: Pinouts and wiring diagrams
