1955 Belair Install
Any assistance/suggestions will be greatly appreciated. Thanks…
a GMPP 4BBL intake and the stuff to convert to HEI.
That gives you some pretty nice heads, a forgiving
compression ratio and no-hassle old school tuning.
The 4L60E you could control with a TCI box (I think
there are other options too) but my money would go
to a really well built 200-4R (dual bolt pattern) for
the simplicity (and more ruggeness I think, and if you
already have a TH350 then the driveshaft would work).
2000 has EGR and smaller injectors. 2001 is simpler
and better fueled. But if you go for the carb who
cares?
Good luck on your project and keep us posted
Pat
on another local board, one of the members asked me for my phone number to give to a guy swapping a LS1 in a 55 chevy.. somewhere around Charleston, SC.... are you the same guy? lol
Good luck!
Try to mod my harness myself using information found on the board, check Frizzle Fry's post in which he post the info on modding the harness:
https://ls1tech.com/forums/conversions-swaps/356063-early-truck-eng-swap.html
I'm also going to try to make my motor mount plates from scrap 1/4" steel using info found on the site also.
BTW: Can you use a jigsaw with metal cutting blades to do this?
I don't know much about the headers yet because I have a 70s camaro front clip grafted and heard that I;ll not have clearance if I use my Mac headers. Any truth to that?
For the fuel system delivery I'm going to try to use the 2001 gas tank and sending unit, how will I put this tank in the frame? That's going to be the tricky part.
Spending all my $$$ now getting the body and frame ready for paint! LOL
Mr.Dude1 – I’m not the same guy, but these are popular conversions… lol
Chevy55 – I’m not keeping the orig steering box but the 605 doesn’t look like a good option either. Rack & pinion kits look interesting. Danchuk has what they call a 670 box that has possibilities. It offers different ratios and is supposed to be much better than the 605. The 670 just hit the market; I hope to see some objective testing soon.
http://www.jimmeyerracing.com/
Good luck with the LS1 in there. I wouldn't mind having one in mine too.
How about using a grinder that's rated 13000 RPM with some cutoff wheels? I think I can get them fairly cheap at HarborFrieght to make the plates.
One more question, What size steel would you use for Boxing the frame?
This site is full of great info and I get the motivation to do most of the work myself from the vast knowledge on this site.
