Conversion folks please list your conversion in here
Old Oct 2, 2019 | 09:52 AM
  #1801
Arnoldpena1223's Avatar
I have a 2000 chevy silverado single cab standard v6 and a 2000 camaro with a bad frame and body, I want to swap the ls1 5.7 to the silverado how can I go about doing that?
Old Oct 2, 2019 | 11:40 AM
  #1802
You list your conversion here, not ask advice. Post in the regular Conversions forum.
Old Oct 14, 2019 | 07:07 PM
  #1803
Bluemissle's Avatar
1981 Chevy c10
4.8L 4l60e (hopefully soon boosted)
Some pics at https://www.instagram.com/jareds_modshop/?hl=en
Old Oct 15, 2019 | 08:15 PM
  #1804
JohnAtMarsAuto's Avatar
MID ENGINE C10
1986 Chevy C10
LSA Twin Turbo
C5 Corvette T56 with F-Body Bellhousing mated to LSA in truck bed.
Old Oct 18, 2019 | 10:21 AM
  #1805
LsTJ's Avatar
Default 01 Tj Ls1 swap
LQ4
408 C.I.D.
Manley 4340 Forged 4.000" Stroker Internally Balanced 24 Tooth
ARP Studs
Manley 4340 Forged H Beam 6.125" ARP 2000 Bolts
2618 Forged +4cc Flat Top
Total Seal CS AP Steel Top Ring
Compression Ratio: 11.1:1 (with my heads)
Frankenstein 317 stage 2 heads and tsp v4 cam (231/234 .629"/.615" 111 LSA) plus the victor junior, 45lb injectors, nick William's 102 with nitrous Express puck system (with purge, heater, remote opener, stand alone fuel system) 3:73 gears and 3500 stall
Old Oct 18, 2019 | 10:29 AM
  #1806
Michael Price's Avatar
Default 243 heads with a TSP lq9 cam package
If I threw some 243 heads on an lq9 and bought a cam package would I need to replace the valve springs too that comes with the cam or would the 243 valves be fine since im changing from a 317 to a 243?
Old Oct 18, 2019 | 10:37 AM
  #1807
This is where you LIST a conversion, NOT ask advice on parts choices. Go to Conversions and Hybrids to do this.
Old Oct 18, 2019 | 10:41 AM
  #1808
Goes2fast's Avatar
You will get more replies if you post your questions either in a new thread or one that is along the same line as your question. This thread is for people to post what they are working on or have completed, not for tech questions.
Oops, someone beat me to it!
Old Oct 20, 2019 | 10:31 AM
  #1809
Azxiana's Avatar
L99(LS3 automatic variant with VVT and AFM) with a six speed 6L80E out of a 2011 Camaro SS along with electrical and other pieces. I had to convert the transmission from a 2WD car output shaft to 4WD truck output shaft.
Dropped into a 2004 Jeep Wrangler Unlimited - The engine mounts from Dave's Customs Unlimited I used are listed for Generation III engines, but Generation IV engines as far as I know uses the same mounting dimensions. It worked fine.
Rebuilt the NV231 transfer case with bigger components and swap the input shaft to mate it to the 6L80E using a Novak adapter.
The hardest part was all the time spent figuring out the correct engine brackets to use. I started with Holley brackets, but they were too wide. I ended up with ICT Billet brackets that tucked the AC compressor and alternator in closer.
I did all of the wiring, harness grooming, and conversion. I kept the Body Control Module(BCM) to run the added door locks, retain factory GM security keys, keyless entry, and a bunch of other stuff. I tossed the stock computer and the instrument cluster gets its data translated from GMLAN to Chrysler PCI with a Scarlet Performance unit.
The Jeep is getting better gas mileage compared to the stock 4.0L with the Chrysler 42RLE automatic. I need to get more data, but it is fluctuating between 18 to 22 MPG right now.
I have a summary thread with pictures over on the Wrangler Forum: https://www.wranglerforum.com/f322/l...j-2340899.html
Old Nov 12, 2019 | 04:45 PM
  #1810
OldFatBald's Avatar
Default L99/6L80 into a 65 Caddy
Smack in the middle of installing an 2011 Camaro L99/6L80 into a 65 Cadillac drop top
Old Nov 17, 2019 | 08:43 PM
  #1811
67Ragtop's Avatar
1967 Camaro Convertible
2005 LS1/4L60
Will edit to pics soon. I bought a project that was started by someone else. I am an old school gear head, but this my first LS swap, and I am trying to sort out what was done and with what parts. My plan is to complete it this winter. Hoping I can get a lot of info on LS1Tech forums to help figure it out!
Old Nov 24, 2019 | 10:40 PM
  #1812
Projectfox91's Avatar
Default 91 foxbody getting a 6.0
Howdy guys sooo I've got a 91 fox lx that's very straight and gutted from a buddy for free. I picked up a lq4 6.0 for 1200$ with 124k miles on it and the 4l60e. After alot of thought I'm gonna just go with a carb instead of efi..I'm gonna keep this swap as simple as I can ..a few questions I have before buying a tube k member kit for my swap from aje. Do they have motor mounts that bolt right up to the 6.0 ? Should I ditch the 4l60 and go with something stronger? I'll be keeping the 8.8 axle in the rear as well.so I'll have to make a driveline to run both flanges.pics to come and I'll start a build thread by this weekend
Old Nov 24, 2019 | 11:09 PM
  #1813
Please read the heading of this thread- CONVERSION FOLKS PLEASE LIST YOUR CONVERSION IN HERE.
If you have questions, please start a new thread below in the non sticky section.
Old Dec 15, 2019 | 07:46 PM
  #1814
LSBuick's Avatar
1952 Buick Special Riviera
'05 LS2 & transmission
1954 Chevy Pickup
'14 LT1 5.3 Ecotec & transmission
Old Dec 16, 2019 | 02:19 PM
  #1815
Blown Budget's Avatar
2011 Jeep Rubicon JKU
2016 L83 mated with an 8L90 that's adapted to a 241J.
Not going the typical kit, so wanted to have a place to detail what I did so if I ever needed to come back to a reference or ask questions in a place familiar with these engines.
Build in process
Old Dec 16, 2019 | 04:41 PM
  #1816
Wayne Meuir's Avatar
1957 Chevy Handyman 2 door Wagon, 5.3l with LS6 Cam, LS6 Intake, otherwise stock. 4l60e
Body is off frame right now. Motor and tranny are trial fitted into frame. Waiting on aftermarket wiring harness I ordered. Tranny will have to come back out for rebuild and new torque convertor. Body is ready to put back on frame after I get the wiring, exhaust, brake and fuel lines done. C6 Vette Z51 brakes on both ends. New Quick Performance 9" with 370 Yukon Posi and CalTracs.
Wayne
Old Feb 11, 2020 | 12:23 PM
  #1817
OldFatBald's Avatar
Getting closer to firing up the LS3 - All of a sudden I have the desire to eat spaghetti!!
Old Feb 12, 2020 | 06:54 AM
  #1818
victory_red_SS's Avatar
05 Victory Red Cobalt SS,
LSX Bowtie Block, 427 CID,
Wilson LS7 Billet intake manifold,
Brodix BP BR 7 BS 300 Heads,
Crower Rocker Arms,
Diamond Pistons,
Callies Crankshaft,
Carrillo Rods,
Vortech V7 YSi-B,
Holley Dominator EFI,
RWD conversion, NHRA 7.5 second Sportsman Certification,
Rossler Terminator 6 Power glide,
Coan torque converter,
Pat's Driveline custom driveshaft,
Strange HD Pro, Ford 9",
Strange Suspension,
SSBC brakes.
forum website project thread
Old Mar 15, 2020 | 04:30 PM
  #1819
Murray's Avatar
Default 1965 gmc/c10
1965 Gmc with some Chevy C10 parts
2008 5.3 LMG Gen IV + 4L60E
Old Mar 29, 2020 | 10:26 AM
  #1820
RestoRod57's Avatar
Default 57 Vette
1957 Corvette, 283 SB
Converted to 1999 Corvette LS1, T56 Magnum, 1997 Gran Sport front suspension, Dana 36 rear from '96 Corvette
