s10 ls1ers
Old Nov 7, 2006 | 04:43 PM
  #821
Sabre002's Avatar
yea and in a 91 S10 with a 5 speed I think the LS1 intake will be just fine on a LM7. Looks cleaner aswell.
Old Nov 7, 2006 | 06:24 PM
  #822
Xtremes10's Avatar
the only thing to make sure you pay attention to is the water pump, because if you keep the truck water pump, it will have to be modified to fit the LS1 intake
Old Nov 8, 2006 | 01:24 AM
  #823
Ls2Sonoma's Avatar
Originally Posted by Jones'n
LS2Sonoma... got any picturesd of your swap? I would like to see the LS2 in an S-10, I have seen plenty of LS1's. did you keep the ETC or go to a cable throttle body? Is it run by the LS1 or LS2 computer?
it looks just like an ls1 except with different cover (which dont fit yet) and has a nifty little 6.0L on the front of the block
i converted to cable and use an LS1 pcm
Old Nov 8, 2006 | 01:30 AM
  #824
bww3588's Avatar
yeah who wants a computer controling their throttle position........
Old Nov 8, 2006 | 01:32 AM
  #825
bww3588's Avatar
also the LS1 intake will clear your hood. i dont think a truck intake will clear a stock hood.
Old Nov 8, 2006 | 06:24 AM
  #826
Jones'n's Avatar
Thanks for the visual. Wouldn't it be going backwards to spend the money on an LS2 and then stick the LS1 intake and TB on it? I thought the LS2 intakes were better?
I was hoping to see a real LS2 swap in an S-10 using the LS2 ECM, inake, and TB. I'd be cusrious to hear what the troubles were vs. an LS1. I'd think electrical would be about the only difference.
Old Nov 8, 2006 | 11:38 AM
  #827
bww3588's Avatar
an LS2 intake is different from an LS1/LS6 intake. the TB is bigger on the LS2 and the LS1 TB wont fit on and LS2 intake. the engines are the same as far as the swap goes. he used the LS1 PCM and lengthened the harness for the knock sensors and the cam and crank sensors. the PCM is virtually the same for the S-10, LS1, LS2...........
Old Nov 8, 2006 | 06:50 PM
  #828
Ls2Sonoma's Avatar
I went with an LS1 intake simply because of cost and availability, i plan to get an LS2 intake so i can get my engine covers on properly (they dont fit ls1 intakes very well)
there are two types of LS2 pcms. 24x and 58x
the 24x is very similar to an ls1 pcm
58x must be run with the appropriate crank
other than that, the only difference is cost... which, again, is why i have the LS1 pcm
  #829
Ls2Sonoma's Avatar
theyre very close, 99 bucket has this info
Old Nov 8, 2006 | 08:35 PM
  #830
Bigdeezs's Avatar
Forkin Sweet ...Who made your headers?
Old Nov 8, 2006 | 08:42 PM
  #831
Ls2Sonoma's Avatar
thanx, i did
Old Nov 8, 2006 | 08:43 PM
  #832
Bigdeezs's Avatar
you have access to a mandrel bender? And whats your rate on building me another set?
thanx, i did
Old Nov 8, 2006 | 08:51 PM
  #833
Ls2Sonoma's Avatar
no, i dont. all the bends were bought, just had to measure, cut, and weld
i dont know what theyre worth yet, but before i make another set id like to get a tig welder
Old Nov 15, 2006 | 12:52 AM
  #834
Ls2Sonoma's Avatar
who let this thread fall to the second page?!
anyway, so continuing on.... is there anyone out there who has done their own wiring? instead of paying someone else to do it?
Old Nov 15, 2006 | 08:32 AM
  #835
eagleuh1's Avatar
Default wiring
I'm doing my own. Haven't seen my truck for a while, been out of town working. But I got the underhood fuse box powered up and cranked the engine over without spark. Throttle body works, Electronic throttle body, real cool. Got fuel spray. Hope to be back by Christmas and have running by end of January. Alldata And Chevy dealer in town were great help. It's 2005 5.3 into 96 Chevy Blazer 4x4 to 4x2.
Old Nov 15, 2006 | 01:17 PM
  #836
Jhankinson's Avatar
I didnt do all the wiring...all i did was got my LS1 harness made stand alone and then chopped the wiring in the truck and made everything work...RWAL, Cruise, A/C, Factory Tach, Everything works just like it came from the factory...and was extremely easy to do also for my year truck.
Old Nov 15, 2006 | 01:57 PM
  #837
BluLS1's Avatar
so what has everyone done about the a/c compressor?
Old Nov 15, 2006 | 10:27 PM
  #838
99 BUCKET's Avatar
cut and box the frame using truck acc.
Old Nov 16, 2006 | 12:18 AM
  #839
BluLS1's Avatar
as in using the truck compressor? what about bracket?
Old Nov 20, 2006 | 05:19 PM
  #840
01WS6/tamu's Avatar
truck bracket
