s10 ls1ers
Old Dec 6, 2006 | 03:12 PM
  #881
bww3588's Avatar
Originally Posted by Ls2Sonoma
damn, you beat me. my best was 7.3 seconds......
Old Dec 6, 2006 | 07:31 PM
  #882
Ls2Sonoma's Avatar
thats because youre still driving an LS1! haha
Old Dec 6, 2006 | 08:13 PM
  #883
bww3588's Avatar
yeah but mine runs
  #884
firefighter's Avatar
DAMN....... that was cold.
Old Dec 6, 2006 | 08:17 PM
  #885
Ls2Sonoma's Avatar
yeah but mine runs
that one really hurt..... @#$% you, im going out right now till i get it running!!!
Old Dec 8, 2006 | 05:39 PM
  #886
01WS6/tamu's Avatar
For those of you who have used the current performance harness on your 98 up s-10's do you have to use the diablosport programmer in order to make your factory gauges work? Or can I just buy the harness and use my hpt pro to program the pcm as I want it and the gauges will work with jareds harness being the trick.
Old Dec 8, 2006 | 06:23 PM
  #887
Ls2Sonoma's Avatar
depending on your application, you dont need to do anything to the gauges...
Old Dec 8, 2006 | 07:49 PM
  #888
01WS6/tamu's Avatar
So essentially as long as I use his harness the gauges will work as they did from the factory regardless of the choice of custom tuning I use. I want to tune it myself with hpt pro but I was not sure if the diablosport had a custom tune in it that made the factory gauges work correctly. Thanks
Old Dec 8, 2006 | 09:44 PM
  #889
99 BUCKET's Avatar
never mind, you got your answer already....
Old Dec 9, 2006 | 12:09 AM
  #890
AceHaag's Avatar
Originally Posted by white98s10
Did you ever find a smaller diameter pulley? I need one for my swap.
no i didn't i ended up modifying my bracket to mount the stock 2.2 ps pump.
Old Dec 9, 2006 | 12:12 AM
  #891
AceHaag's Avatar
Originally Posted by LSWaaa?
can anyone answer my question???
do you want a stick or and auto? only you can answer the question.
Old Dec 9, 2006 | 08:02 AM
  #892
Jones'n's Avatar
I don't think it is anything special with the Tuner that he is using, just the programming.
I know that in order to make some of the stuff work right, it takes a little trickery. In most S-10 apps, you can't just stick a Camaro program in the computer and have everything work right.
Old Dec 9, 2006 | 02:08 PM
  #893
randyc's Avatar
I found with my 2000 Noma using a truck computor all the guages worked properly including the tach, except the gas guage. The computor had to be re-programmed in the fuel level area to have it read with the right scale. I presume as the engine programming was from a full size truck that the gas guage was for a larger tank. All is good now.
Old Dec 9, 2006 | 06:53 PM
  #894
01WS6/tamu's Avatar
Ok that is the kind of stuff I'm huntin for. THanks
Old Dec 9, 2006 | 07:08 PM
  #895
Ls2Sonoma's Avatar
depending on your application, in order to make it work right, you just have to connect wires. basically, the pcm must be tuned so that the gauges read accurately, but thats something that you should do anyway. things like vats delete and turning off MIL indicator for DTCs like a common alternator incompatibility error or missing wheel sensors...
what im trying to say here, is, if you have the money, spend it on a wiring harness. if you dont mind to do the work yourself, do your own harness... because you can and its not hard
Old Dec 10, 2006 | 08:11 PM
  #896
Ls2Sonoma's Avatar
this is for you brandon! shes ALIVE!!!!!!!
http://videos.streetfire.net/video/e...93015a7c1d.htm
Old Dec 10, 2006 | 08:23 PM
  #897
01WS6/tamu's Avatar
Link es not loading damm
Old Dec 10, 2006 | 09:18 PM
  #898
It eeeess ALIVE! Congrts man. I bet you can't wait for the spring so you can start beating her like a rented mule.
Old Dec 11, 2006 | 01:16 AM
  #899
Ls2Sonoma's Avatar
that sounds fun, but my baby will never get beaten on =]
yea, spring cant come fast enough!!
Old Dec 11, 2006 | 06:31 PM
  #900
bww3588's Avatar
this is for you brian! shes ALIVE!!!!!!!
Brian? if your reffering to me its Brandon. lol j/p. glad to hear she is running. what was the final verdict on the problem?
