s10 ls1ers
Old Dec 11, 2006 | 07:03 PM
  #901
Ls2Sonoma's Avatar
Originally Posted by bww3588
Brian? if your reffering to me its Brandon. lol j/p. glad to hear she is running. what was the final verdict on the problem?
haha, oops...
turned out to be a cam sensor problem
Old Dec 11, 2006 | 08:16 PM
  #902
99 BUCKET's Avatar
mine too is alive again!
Old Dec 12, 2006 | 05:28 PM
  #903
firefighter's Avatar
went Vette shopping today....... too bad it wasn't for me it was for my wifes uncle. SUX *****!!!
Old Dec 12, 2006 | 06:29 PM
  #904
bww3588's Avatar
Old Dec 12, 2006 | 09:25 PM
  #905
Xtremes10's Avatar
so who changed the brake booster rather than relocate the coil?
Old Dec 12, 2006 | 10:23 PM
  #906
01WS6/tamu's Avatar
hydraboost on mine but I put it on about six years ago. Robbed it off an astro van
Old Dec 12, 2006 | 10:43 PM
  #907
99 BUCKET's Avatar
I used the round coils, no relocating.they have different brackets that mount higher
Old Dec 13, 2006 | 07:03 AM
  #908
Jhankinson's Avatar
Same here used the truck coils...at first i used the fbody coils...then decided i hated the look and changed to the trucks...now its so nice and simple looking.
Old Dec 13, 2006 | 06:42 PM
  #909
Xtremes10's Avatar
I have the van coils, guess it is different than truck?
Old Dec 14, 2006 | 10:33 PM
  #910
01WS6/tamu's Avatar
Guess the hydraboost I put on with the six cyl will come in handy when I start the ls swap here pretty quick. The brakes were terrible with the stock booster.
Old Dec 15, 2006 | 01:56 PM
  #911
s10-den's Avatar
So,does anyone have pics of the fuel pump and what theyhad to do to it?
Old Dec 15, 2006 | 10:32 PM
  #912
01WS6/tamu's Avatar
Nothing it will work fine as furnished from gm.
Old Dec 16, 2006 | 02:26 AM
  #913
Ls2Sonoma's Avatar
depends on the year of the truck, then you still need to mod the steel lines. it must make 58psi (4 bar) to support any Gen III/IV engine.
id say i went the simplest route with my fuel setup. stock pump (for now), vette return style fuel filter, oem plastic lines w/ quick disconnect fittings. pump not included, cost was around $100cdn.. ill post a few pix saturday for ya den
Old Dec 16, 2006 | 05:48 PM
  #914
So-GT0071's Avatar
I actually did neither. 98 LS1 from a T/A into a 92 Sonoma GT. I used the stock brake booster and the coil that came on the engine. I'd say it has about 1/4-1/2 inch of clearance. I've been drivin it around and haven't had any problems with it yet
Old Dec 16, 2006 | 10:02 PM
  #915
Bigdeezs's Avatar
I think different trucks came with different brake boosters or sumthin...either that or the motor mounts are mounting the engines higher or lower...I welded modified camaro mounts in keeping the motor super low(like 1/4" clearance from the cradle to oil pan) and I had no coil to booster clearance issues either
Old Dec 17, 2006 | 09:30 AM
  #916
jay_lt4's Avatar
i used a brake booster from a 2001 chevy malibu for my 6.0L 1999 s-10 , it is only 9 1/2" and gave me alot more room for the drivers side coils
click on the pic for a vid of it running:
Old Dec 17, 2006 | 11:17 AM
  #917
So-GT0071's Avatar
Yea must be ...my motor sits pretty low as well.
Old Dec 17, 2006 | 11:31 PM
  #918
V8sonoma's Avatar
ive got a 1995 sonoma with a 434ci small block in it right now and i got a 99 sonoma ZQ8 that i am putting a ls1 and a 6spd in it... its a 4cyl auto. truck and i heard that you can use the stocky 4.3L fuel lines... what kind of madifications do you have to do with these fuel lines to make them work? also do these fuel lines need to be from a 5spd truck or a automatic or does it matter?
Old Dec 18, 2006 | 01:03 PM
  #919
s10-den's Avatar
that will work....
Old Dec 18, 2006 | 11:13 PM
  #920
01WS6/tamu's Avatar
Well as far as the fuel lines go I went to a salvage yard and cut a pressure and return line off about midway down the bellhousing from a fullsize. Since I am going to use truck accessories and intake the fuel lines should work. I am going to cut off the the stock 4.3 fuel lines and then either make a flex adaptor out of hydraulic line with crimped fittings or just use compression fittings and see if it will work.
