s10 ls1ers
Old Feb 9, 2008 | 09:57 PM
  #1461
LSXS10's Avatar
My truck is at dads in the shop, ill try to snap some header pics in and out if the truck, ive got to get em coated !!! they rusted over the winter look like shat! ... Thanks for the pics Frank...
Old Feb 9, 2008 | 10:31 PM
  #1462
Frank02L's Avatar
No problem. maybe they'll help out a little bit for ya.
Old Feb 11, 2008 | 08:52 AM
  #1463
lt1s10's Avatar
Some pics of the mock up. I need to build a mount for the heim so it can be removed easily. The booster is a malibu, the pan is h3, the mounts are carshop. The arms and steering parts came from ub machine.
Old Feb 11, 2008 | 09:53 AM
  #1464
Frank02L's Avatar
Originally Posted by Frank02L
I'll try to get you pic from the top this weekend.
Took some new pics this weekend but I forgot about the steering through the top. The column wasnt "in" it anyway so probably couldnt see exactly what was going on. (in place just for scaling purposes)
It looks alot like that picture, except through the header tubes, and it goes through the crossmember.
Old Feb 11, 2008 | 06:15 PM
  #1465
RDTA's Avatar
here is a old pic of the steering, it goes between cyl 3&5 through the crossmember and out to the rack. with 3 u joints and 1 stablizer heim.
Old Feb 11, 2008 | 07:02 PM
  #1466
LSXS10's Avatar
You guys are going to cry after you se my header pics , in going to take some this weekend 1-7/8 longtubes in the frame and nothing below the frame on the bottom also equal lenth can you say sumbeach!!!!
Old Feb 11, 2008 | 07:16 PM
  #1467
LSXS10's Avatar
Hey Frank , I seen you had a plate where the brake booster was i done the same thing and used a willwood manual mc and the pedal is ROCK hard! yall thought about pedal ratio? think were going to have to do something there! Any ideas, im thinkin move the pivot bolt down and redrill it in the truck, then shorten the pedal from the pivot to where the rod hooks but im not sure, was tolt those mc's take a 8:1 ratio...ours is 5:1 i think for power brakes but more leverage should up the ratio i think...
Old Feb 11, 2008 | 07:41 PM
  #1468
RDTA's Avatar
I dont know on the pedal ratio. we went with a 1 1/8 bore strange m/c. might have be in the same boat as u. we are using aerospace brakes in the front and rear. the rears are the dual caliper ones. I know on franks truck those made the pedal real soft.
Old Feb 11, 2008 | 07:58 PM
  #1469
LSXS10's Avatar
I have about 1" of pedal tavel then it is just gets hard i have to push like hell to get it to stop its got stock front brakes and would stop on a dime on a 109 mph pass with the power brakes. older s-10s stopped fine with manual brakes i think its got to do with the pedal but i dunno..
Old Feb 12, 2008 | 11:34 AM
  #1470
Frank02L's Avatar
We're gonna try it and see but I figure it may have to be moved.
Old Feb 12, 2008 | 06:46 PM
  #1471
LSXS10's Avatar
Ill post yall up some pics if i figure it out it will be a week or two dash is coming out for cage and ill change it then...
Old Feb 14, 2008 | 11:18 AM
  #1472
Frank02L's Avatar
Originally Posted by webtester
You said about brake boosters.
Could I know more about?
Old Feb 14, 2008 | 11:41 AM
  #1473
m8w6r77's Avatar
man this thread just keeps growing. lol.
Old Feb 15, 2008 | 05:17 PM
  #1474
Superman09's Avatar
LS1Tech Sponsor
I have a 2000 Reg Cab Sonoma 2.2l 1 tire fire w/ 141,000 miles. Also have a spare ls1 longblock and 4l60-e trans in my garage.... i think its itching to find a new home under the hood of the sonoma. I've researched this a few times but still have some more questions if you guys could help me out. I know i want to run C5 vette accesories.
1.) For the 4l60-e, do i want the f-body tailshaft?
2.) What type of trans crossmember are you running?
3.) Any driveshaft shortening needed?
4.) Whats the go-to rear-end to get a limited slip setup? Stock f-body rear ends work?
5.) What are you using for computer and wiring harness?
6.) Whats the best oil pan ATM, i know some use vette pans and truck pans... whats the one to go with?
7.) Are you using the stock AC system, or the C5 ac accessories?
8.) What are some nice headers that fit the conversion nicely?
Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Feb 15, 2008 | 05:57 PM
  #1475
99DWPTA's Avatar
LMAO 1 tire fire. God i love when people say that!
Old Feb 15, 2008 | 09:36 PM
  #1476
Horsepwraddict's Avatar
Just curious, after looking at my '99 F-body manifolds today and pondering while i had nothing better to do. Will a set of F-body shorties fit our trucks? I cant imagine they would be too far off, maybe fit with a little persuasion?
Anyone tried it? Sorry if its been discussed, i cant remeber everything in this thread.
Old Feb 15, 2008 | 09:43 PM
  #1477
RDTA's Avatar
I bet they will. the header maybe a little thicker. (as far as distance away from the head)
Old Feb 15, 2008 | 10:00 PM
  #1478
This is a set of BBK shorties with 1-3/4" primaries. The tubes look like they tuck pretty tight for steering shaft clearance, and clearance isn't much of an issue on the passenger side, as long as the flange clears the firewall and leaves room to route a pipe off it....i think it may work.
These edelbrocks with 1-5/8" primaries look like the tuck pretty tight too. You may have to hack off the flange on them and weld an extension like on the stock manifolds..but for the bigger primaries, it may be worth it.
Old Feb 15, 2008 | 10:37 PM
  #1479
jay_lt4's Avatar
for the price to try the f-body headers you can get the sanderson shorty ls1/s-10 headers for $225, they fit very good and come with collectors
http://www.sandersonheaders.com/prod...roducts_id=191
Old Feb 15, 2008 | 10:41 PM
  #1480
i agree, but alot of people complain of the small 1.5" primaries.
