s10 ls1ers
Old Feb 24, 2008 | 10:21 PM
  #1521
Frank02L's Avatar
Cool square body LS1!
Looks good with the prostars on it too.
Old Feb 24, 2008 | 10:56 PM
  #1522
01WS6/tamu's Avatar
Anyone want to see paint shop progress pics. Truck has been elevated to purgatory now instead of paint jail. I can post them if anyone wants
Old Feb 24, 2008 | 11:10 PM
  #1523
Ls2Sonoma's Avatar
im waiting....
Old Feb 24, 2008 | 11:16 PM
  #1524
black2002ls's Avatar
anyone have injectors laying around for a 2.2? Mine is going in the shop to take care of a miss tomorrow, I expect them to say I have a bad injector on cylinder 3. On with the paint pics!!!!
Old Feb 25, 2008 | 01:54 AM
  #1525
Bigdeezs's Avatar
Originally Posted by drwoowoowoo
Ill take some more detailed pics later on
Good thing you're running that cowl hood for that big motor and all the extra room you need ...LOL just messin but with these swaps a person could run a reverse cowl and still have plenty of room!
Old Feb 25, 2008 | 07:18 AM
  #1526
Horsepwraddict's Avatar
..i wish...with my carb intake my air cleaner just barely grazes the hood. If it were a single plain, no way in hell it would fit. I think i might try running one of those edelbrock foam triangular filters.
Old Feb 25, 2008 | 11:06 AM
  #1527
andrew69_04's Avatar
just started my swap tonight. i started a thread on s10forum. check it out if you want. i might put some pics/vids of it on here when im all done since im on this sight way more than that one anyways.
http://www.s10forum.com/forum/f213/s...inally-339910/
Old Feb 25, 2008 | 04:25 PM
  #1528
drwoowoowoo's Avatar
I have edelbrock intake and msd box left over from my g/f's 89 ls1 firebird. But im gonna give this FI thing a run for a while. There are some guys going real real fast with EFI
Old Feb 26, 2008 | 11:42 AM
  #1529
s10-den's Avatar
big dee,didnt you say you cut the motor mount towers off your blazer when you installed the motor???
Old Feb 26, 2008 | 06:44 PM
  #1530
BluLS1's Avatar
i'm sure this has probably been answered and probably won't work with my luck but will a truck intake fit under the hood?
Old Feb 26, 2008 | 07:03 PM
  #1531
Ls2Sonoma's Avatar
of course its been answered... the truck intake is supposed to fit, i heard that its the alternator and engine cover that hit the hood.... however, it may depend on mounts
Old Feb 27, 2008 | 01:26 AM
  #1532
Bigdeezs's Avatar
yup...i wanted my motor to sit as low as possible and S10s dont have em so i figured it would be okay. Also I've heard of high HP guys riping off the driver side tower when the motor torques.
Old Feb 28, 2008 | 09:09 PM
  #1533
BORN2FLY's Avatar
Thumbs up
THANKS. There is so much helpful info in this thread.
Old Feb 28, 2008 | 11:37 PM
  #1534
Ls2Sonoma's Avatar
buddy... wheres our pix!?
Old Feb 29, 2008 | 12:26 AM
  #1535
BluLS1's Avatar
okay, so if i use this intake will it throw me off fuel wise. i was originally gonna use an f-body intake and fuel rail.. the truck intake is basically the same set up isnt it.. or is it more like the vette fuel rail with two fuel connections.
also, i'm leaving my mount towers, would this be an issue??
Old Feb 29, 2008 | 09:02 PM
  #1536
Ls2Sonoma's Avatar
the two connections youre thinking of is early style. one is a return, whereas in the newer systems, the return was in the filter... thats why you hear people talk about the vette filter. you can run either system, just dont mix and match the two.
the bigger intake will change the airflow slightly since one is a larger volume, but if you keep the maf, i wouldnt expect a huge change where you couldnt drive it.
sorry, i dont know about your mount towers
Old Feb 29, 2008 | 11:51 PM
  #1537
01WS6/tamu's Avatar
I just got back home from taking a test fo rmy masters. I;ll have em up tomorrow evening fo sho.
Old Mar 3, 2008 | 09:43 AM
  #1538
Just a couple of pics from this weekend, you know its a sad day when yo put a kit on your ride to try and get around a trailblazer
We had a problem with the nozzle i put on the truck, the fuel pills were to much for the juice so we cut the fuel noid outta the picture and ran a dry shot it was only a 50 dry shot it was a fender the whole way until he hit his second stage and made it a 1 car difference
Old Mar 3, 2008 | 02:54 PM
  #1539
lt1s10's Avatar
Old Mar 3, 2008 | 08:23 PM
  #1540
which oil pan are you using? your engine looks like its sitting pretty low
