Drag Racing Tech
Would a 30" tire slow me down?
Old 12-18-2008, 04:47 PM
TS6
TS6's Avatar
Default Would a 30" tire slow me down?
I've been running 28" tires for years, but since I went TH400 I would like to go to a 30" not only for traction but to lower rpms while driving. I was thinking about getting the 315/60/15 or the 295/65/15.
I'm trying to go mid-upper 9's, I shift at 6500, TH400, 3.73 gear, 4000 stall. Currently making 615 RWHP through the TH400, motor makes around 800-850 crank HP.
Also, while I'm at it, why are cars "faster" on radials than slicks? Is it just rolling resistance?
Old 12-18-2008, 04:51 PM
dlove's Avatar
What is your trap MPH? and what is your converter slipage?
Old 12-18-2008, 04:58 PM
TS6
TS6's Avatar
Not sure on slippage, haven't got to run this setup yet (yay winter!). Its and FTI convertor and they claim 2-3% slippage. My best trap speed was 139.3 with 28" slicks and a 4L60E locked in third. MPH is usually around 136-137 so far, don't have alot of passes.
I just wanna make sure I'm not shooting myself in the foot going taller. I ran the 4L60E unlocked and didn't hit my limiter, not sure how the TH400 will fare.
Old 12-18-2008, 05:02 PM
Camaro396's Avatar
Thats alot of tire for a 3.73 geared car that your shifting at 6500....Im going to shift this setup at 7000 with a 4.10 & 28" tires.
Old 12-18-2008, 05:15 PM
dlove's Avatar
f-body.org/gears
Old 12-18-2008, 07:56 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
30" tires look lame on these cars, like tractor tires. I would try to avoid it. I went 9.4 on 325 dr's it's not that hard.
Old 12-18-2008, 08:18 PM
1cdub's Avatar
They don't look lame if you fit them correctly...most don't.
Back on topic, I'd make some test hits before making a tire change. Too many variables to be guessing with the new combo.
FWIW, my car picked up 1 mph and 1 tenth going from 28" ET drags to Hoosier 295 dr's which are about 29.5"
Just to give you some comparison #'s..this car runs 9.9's at 133 with 295 Hoosiers, 5000 stall, 4.10's, th400. Goes thru the traps about 6800.
Old 12-18-2008, 09:27 PM
TS6
TS6's Avatar
Yeah, if I do it I will tuck them so it doesn't look ghetto.
Old 12-19-2008, 01:26 AM
BlackWS666's Avatar
I know it looks cool and everything man, but I think its way overkill..... But I'm totally down if you wanna do it. Kinda want to tub out one of these cars, just for the experience
Old 12-19-2008, 01:56 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
I think the 30" tires look good when the proper off-set is used. We didn't have to tub our car. It just took some strategic BFH work.
The radials provide a much stiffer sidewall and radial ply that greatly reduces rolling resistance. The other benefit is how the make the car much more stable going down the track.
Old 12-20-2008, 10:35 AM
tektrans's Avatar
I have the 30" Hoosiers (they don't look ghetto John ) you just gotta fit them like TXCAMSS said.
I have 3:73's as well and I'm going thru the traps at 6600 FWIW.
Old 12-20-2008, 11:12 AM
9sec93's Avatar
see 30" tire in sig
Old 12-20-2008, 12:07 PM
SPEEDYws6's Avatar
Madman got mine looking great sitting on 30's out back. Stock length rear with 15x10 7.5 bs wheels tucking tire. I'll load pics later.
One day I'll get back to the track and see what the taller tires do for me.
Old 12-20-2008, 12:22 PM
TS6
TS6's Avatar
Get pics up asap! I wanna see!
Old 12-20-2008, 02:28 PM
ndfrsd6's Avatar
^^^ same pics please
Old 12-20-2008, 04:25 PM
TS6
TS6's Avatar
The only thing I'm trying to avoid is cutting the 1/4 panel in front.
Old 12-20-2008, 04:27 PM
SPEEDYws6's Avatar
Give me your email I can send a few I have on my phone. I don't have my cable to load them on the computer.
Old 12-20-2008, 04:38 PM
TS6
TS6's Avatar
My email is turbosam6@yahoo.com
Thanks!
Old 12-20-2008, 04:46 PM
ndfrsd6's Avatar
^^ pm sent
Old 12-20-2008, 06:54 PM
tektrans's Avatar
I don't think you can avoid that.
