Drag Racing Tech
Rear anti rollbar/drag sway bar...
Old 01-02-2009, 09:08 AM
patriotformula's Avatar
Default Rear anti rollbar/drag sway bar...
Hoping to see some pictures of these installed or uninstalled and the different options. Did a search and couldn't find much. Post up what you got, or what you've found fellas!
Old 01-02-2009, 09:31 AM
96LT1355Z28's Avatar
Midwest Chassis anti-roll bar with their 9".
Attached Thumbnails Rear anti rollbar/drag sway bar...-3.jpg
Old 01-02-2009, 11:15 AM
LS1Tech Sponsor
MADMAN's Avatar
We use either the BMR Xtreme duty or the Wolfe.
__________________
www.madmanandcoracing.com
225-343-9029
Old 01-02-2009, 12:17 PM
ndfrsd6's Avatar
here's mine i have a stange 12 bolt w/ a Spohn Pro-Series Rear Drag Sway Bar and an adj Spohn panhard bar
Old 01-02-2009, 12:37 PM
LS1TECH Sponsor
Steve Burger's Avatar
We use BMR or ours. The pics of ours are on our site.
Old 01-02-2009, 05:28 PM
Dan / Wolfe Race Craft's Avatar
What are you doing with the car? Street, if so how much? Race only?
Old 01-02-2009, 06:00 PM
It will be mainly strip... Going to drive it to carshows from now and then though.
Old 01-02-2009, 10:28 PM
Race your car!
JL ws-6's Avatar
Get a wolfe single adjustable. You won't regret it.
You can sort of see one on my car in the sig pic
Old 01-02-2009, 11:35 PM
JRracing's Avatar
Anti roll bar for a drag car.
Sway bar for a street car.
I had a sphon drag sway bar on my camaro. It was a heavy *** piece. Very stout!
I also just put a anti roll bar on this fox body mustang. Tucks up in the frame rails. Pretty lite.
Dan, If one wants to drive a drag car on the street that has a anti roll bar, what should be done to drive it on the street? Dis connect the links and tie up the tabs on the bar so they don't hang down(between the frame rail style)???
Old 01-03-2009, 07:56 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
I run the Wolfe bar on my Camaro & it works fine under normal driving.
It even handles rather nicely, but do not try to road race as it will oversteer when pushed hard.
The only problem I have is when turning into a steep driveway, as it will pick 1 back tire off the ground since the rear does not lean like it does when stock.
You can also pick 3 tires off the ground (2 fronts & 1 rear) by jacking it up behind the front tire. Makes it easy to change the front tires without trying to lift it by the front crossmember.
Old 01-03-2009, 10:04 PM
1999TransamWs6's Avatar
This is one they did on my rear from billingsley before they closed shop. Not the best pictures but all I have right now.
Old 01-03-2009, 10:49 PM
OutlawZ's Avatar
I use the BMR..... works friggin great. I used to have the Wolfe and I liked it too.. I went over a speed bump and wrecked it........ teh only way to repair it was to completely cut it off with a plasma cutter....
Old 01-03-2009, 10:53 PM
ATwelveSec02Z28's Avatar
I have the Wolfe, rear is currently out of the car, not sure if you want pics of that... can take some tomorrow
Old 01-04-2009, 12:04 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
i have the chromemoly tubular design that bolts onto the rearend, similar to the pic in post #2. it is lightweight and strong, can be removed if needed. what rearend is in your car?
Old 01-04-2009, 12:49 PM
Yeah any pics would be great...
Erik,
I've been trying to contact you about getting a fab 9 built, but gave up when there was no response to my phone call or email...
Old 01-04-2009, 06:31 PM
Here is one with the rear in the car, and 2 with it out.
Old 01-05-2009, 01:05 AM
1BADAIR's Avatar
spohn
Attached Thumbnails Rear anti rollbar/drag sway bar...-bar.jpg
Old 01-05-2009, 09:07 AM
BMR Tech's Avatar
Here are a a few images of our XSB001. Let me know if you have any questions
Attached Thumbnails Rear anti rollbar/drag sway bar...-xsb001.jpg   Rear anti rollbar/drag sway bar...-dragbar-installed3.jpg
Old 01-05-2009, 12:11 PM
z28rob18's Avatar
i just got a spohn drag sway bar with the rear i bought and its a real nice piece cant wait t have it in the car
Old 01-07-2009, 09:17 AM
wlsmoku's Avatar
Wolfe Anti sway - great fit and it drives fine for the street as well.
Quick Reply: Rear anti rollbar/drag sway bar...
