Search is down: What is an Edelbrock Victor Jr worth over a Fast 90/90?
#65
Is that an NA set up? If not where do you have your noids mounted? What's the 2nd vacuum line coming off of the T/B for?
Originally Posted by LOnSLO
I didn't cut anything, but I don't run a filter either. Never seen a race car with a filter.
Picked up over 40rwhp over an LS2 manifold. Dropped 3 tenths also. Nuff said. This was on my 408
#69
Here's some of the threads from the past:
https://ls1tech.com/forums/generation-iii-external-engine/105407-carb-intakes-ls1-s.html
https://ls1tech.com/forums/generation-iii-external-engine/112195-new-edelbrock-ls1-intake.html
https://ls1tech.com/forums/generation-iii-external-engine/148639-new-carb-ls1-setup-made-40-hp-over-ls6.html <<results
https://ls1tech.com/forums/generation-iii-external-engine/158658-gmpp-ls1-intake-availbility-update.html
https://ls1tech.com/forums/generation-iii-external-engine/168311-war-intake-accel-teaser-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/173568-more-war-gmpp-intake-pictures-big-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/198601-gmpp-singleplane-tested-new-popular-hotrodding-mag.html
https://ls1tech.com/forums/generation-iii-external-engine/267311-carb-ls1-intake-converted-efi.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/305750-why-more-people-not-running-gmpp-intake.html <<pictures
https://ls1tech.com/forums/dynamometer-results-comparisons/311005-spm-hptuners-dyno-results.html <<dyno results
https://ls1tech.com/forums/generation-iii-external-engine/314549-carbed-intake-converted-f-i.html
https://ls1tech.com/forums/generation-iii-external-engine/320023-gmpp-carb-efi-conversion.html
https://ls1tech.com/forums/forced-induction/327044-new-intake-arrives.html
https://ls1tech.com/forums/generation-iii-external-engine/334178-who-do-machining-gmpp-single-plane-manifold.html
https://ls1tech.com/forums/generation-iii-external-engine/354540-vic-jr-intake-ls1.html
https://ls1tech.com/forums/generation-iii-external-engine/379735-edelbrock-victor-jr-intake-pics-specs.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/381677-various-single-plane-intake-pics-big-pics.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/392724-putting-carb-ls1.html <<Lots of Pix
https://ls1tech.com/forums/generation-iii-external-engine/414468-gmpp-intake-vs-edelbrok-victor-jr-ls1.html
#72
any more updates on this subject. were do you guys find these throttle bodys? I already have a fast 90 tb and intake. My setup is et240s 12:1cr 408 cam is still undecided. I found the intakes but not the tb that bolt directly to the intake.
#73
now i did more research and the only question i have now is if i run an accel or accufab 4150 throttle body can i use the iac and tps that come with them.
I will be using the 98 ls1 stock computer. I am confused about the electronics
#74
