SFI 25.2 Mustang/LSx build "The Renegade"
#2982
LS1Tech Sponsor
#2984
I got the turbo and radiator mounted, cut a hole in the firewall outside the frame rail for the intercooler pipe. Last year I ran the IC pipe next to the valve covers and it made it a hassle to pull and change plugs. Now I am going to run it right next to the passenger side frame rail.
Mark sent me a mounting boss to put the water pump on the radiator, still need to do alittle work on the drill press to mount the water pump to the 1/4" billet flange.
I centered the turbo up front and rotated the turbine housing so the elbow coming into the turbo will be centered between the frame rails, cone engineering has a collector and some transitions to go from the 3" collectors to the 2.5" tubing for the crossover tube.
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00856.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00859.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00855.jpg)
5" turbo Y pipe to 4" dual exhaust
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00857.jpg)
Inside of turbo Y pipe
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00858.jpg)
#2985
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
looks good...are you going to cut the ears off of the radiator? doesn't look like you're using them...
hopefully that "point" in the middle of your merge don't burn thru from the exhaust
is that the RPS turbo mount flange?
#2987
whatcha waiting for...weld it up ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I'm going to see if my local shop has any of those rare earth tungstens...I'll let you know how they work out on the aluminum...
#2988
what machine are you welding with-the thoriated works great on inverter machines like the dynasty.We have an old syncrowave and use the zirconated tungsten-damn hard to find anymore though.
#2989
I have some rare earth on order (supposed to be the cat's meow for inverter machines)
#2990
BullhornsTTFMF!
In all seriousness though, I was talking to some guys down in Georgia back in February about the bullhorns on their car. They said they scaled the car back at their shop, and the car weighed 3300LBS. They brought the car up on the transbrake with normal exhaust coming out the fenders, and the car still scaled 3300LBS. They brought the car up on the brake and built boost, and the scales showed 3600LBS! They said they werent sure how much the horns were helping, but knew they werent hurting anything!
#2992
BullhornsTTFMF!
#2993
#2995
Damn Phil, you keep that up John Marcella may just have some serious competition in the near future!!! I wish changing a regulator will make my welds look that good. Dude that's a nice looking bead!!!! Keep up the good work....
-Dave
-Dave
#2997
As far as settings, 125amps, 80Hz , 68 balance, orange tungsten, 3/32 filler, 14g tubing, gas lense #9. I think the wide cleaning action is a combination of the 80 hz and the 68 balance.
#2998
Marcella aint got **** to worry about, I am just a hobbyist. Considering that was my first bead today and I didn't really warm up or try to get into a good dap-move rhythm so I'm happy. I was worried that I lost my aluminum skillz.
