Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 03-21-2008, 06:39 PM
  #481
7 Second Club
Phil99vette's Avatar
Got some more work done, basically cleaning and getting ready to paint the bottom....
Old 03-21-2008, 08:52 PM
  #482
7 Second Club
Got some more work done this evening....
- Got the door panels on
- Windows are scraped and ready for some 20% 3m film
- Bottom of the car wiped down with acetone 2x to remove dirt and wax for paint
- Engine bay && trunk cleaned
- Engine is basically ready to go in, still need to pull the oil restricters and torque the pan down
- Still need to swap the stator in the Chance converter for the M/T rubber
We'll paint the bottom of the car saturday or sunday and the motor will be in either sunday night or monday morning
Old 03-22-2008, 06:51 AM
  #483
Fireball's Avatar
double check the rulebook on the tint...I don't think they allow it for competition...
Old 03-22-2008, 09:35 AM
  #484
7 Second Club
Your right but I know NHRA says no tint but IHRA I think may be different.
Old 03-23-2008, 12:20 PM
  #485
7 Second Club
Got the bottom of the car painted today. Started with a etching primer and finished with Chassis Black. Going to let it dry and drop the powerplant in.
Old 03-23-2008, 04:43 PM
  #486
7 Second Club
DAYAMM 96,122 views between this thread and the one in conversions.
Old 03-23-2008, 04:50 PM
  #487
87Lt1Monte's Avatar
BADDD **** thats why!
Old 03-23-2008, 11:21 PM
  #488
7 Second Club
Didn't get much done this evening.
Pulled down the front timing cover
Removed oil restrictors from lifter galleys
Swapped ARP Cam bolts
Added plugs for old oil pump passages
Swapped stator in Chance Converter
Need to pick up a piece of aluminum and a front timing cover seal tomorrow. Motor will be in my thursday.
Old 03-23-2008, 11:54 PM
  #489
Harley-Davidson88's Avatar
No doubt
Old 03-24-2008, 06:04 AM
  #490
Fireball's Avatar
Looks great phil...bet cleaning the underbody was not fun
Old 03-24-2008, 05:56 PM
  #491
7 Second Club
Thanks man, hopefully I can check your car out when I take it over to Tysons to scale it.
Old 03-24-2008, 06:56 PM
  #492
Fireball's Avatar
should be back there in 3 weeks...shouldn't be there terribly long though.
Old 03-27-2008, 10:29 PM
  #493
7 Second Club
Today got a few things done....
- Motor is in
- Powerglide/Chance converter are in and bolted in place
- PCM mount is done getting painted
Tomorrow we're going to install the BS3 and start finishing up the wiring harness, there are 2-3 plugs that need to be changed over. Motor plate is at the machinist and should be done tomorrow.
Old 03-27-2008, 11:27 PM
  #494
SSilverSSurfer's Avatar
kick ***, keep up the good work its almost there
Old 03-28-2008, 03:46 PM
  #495
slammer454's Avatar
I can't think of anything creative or witty to say. this car is just that sweet.
Old 03-28-2008, 03:51 PM
  #496
RAGENZ28's Avatar
Time for some photo updates....
Old 03-28-2008, 10:56 PM
  #497
7 Second Club
Just one pic of the motor inplace. The rear motor plate and the trans crossmember are bolted inplace. The driver side plate should be ready sunday.
Old 03-29-2008, 11:41 AM
  #498
RAGENZ28's Avatar
carbon fiber valve covers, you are Phil.
Old 03-30-2008, 03:58 PM
  #499
7 Second Club
Completed:
Cut/Assembled spark plug wires
Mouted Line lock
started on front brake lines
Changed IAC/TPS/MAP harness connector
Installed headlight buckets and headlights
Starting to come together...
Old 04-04-2008, 08:39 AM
  #500
7 Second Club
Thrashing aint the word for it. Didn't have too much time yesterday, I took my son to the doctors yesterday morning since my wife hadn't gotten much sleep in the last couple days and watched him for a couple hours to mom could get some much needed rest. Got to work about 2ish. Here is what we got done....
Primed and Painted - Rear, control arms, parachute mount, parachute holder
Wolfe lower control arms bolted up
Moser 9" installed
AFCO shocks bolted down
Single upper control arm(get pinion angle, side to side, and front to rear correct)
Installed Mark Williams Driveshaft
Fuel cell, water tank, battery box w/ 16 volt battery are in
Custom Wiring harness arrived from Painless Performance
Cut the front K-member in 1/2 and removed the center bar
Mocked up front suspension and aligned wheels for removable center bar fabrication
Worked on installing front bumper, doesn't seem to fit just right
Got head lights installed
Tonight we're going to work on door and fender alignment and a possibly install some carpet.
Phil
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
